Should I buy a decent 27" 4K monitor, or a full HD or 2K 31" monitor.
I use my PC Mainly for gaming, and I know there aren't many 4K games out yet, but is it worth to invest?
I got around 450$ to spend, and play some FPS games and LoL and DotA 2.
Thanks <3
SPECS
Motherboard= ASUS P8P67 LE
Graphics Card= MSI AMD Radeon HD r6950 Series
CPU= Intel Core i5 2500K Sandy Bridge
RAM= 20GB DDR3
HDD= 1TB Data
SSD= 120GB Data
Cooling= Some Shapty windmills..................
MadCatz STRIKE 5 Keyboard
Razer Ouroboros Gaming Mouse
Sennheiser G4ME Zero 2.1 Headphones w/ Virtual Surround
Monitor= Samsung SyncMaster B2440
Planning to upgrade tol gtx 970...
https://linustechtips.com/topic/295343-help-plis/
Thanks <3
What are your pc specs? For lol and dota definitely 4k imo.
sudo chmod -R 000 /*
https://linustechtips.com/topic/295343-help-plis/#findComment-4009734
I'm no expert but my opinion is that it may be nice to invest in a 4k monitor. Even though there arent many games out yet that are 4k compatible, you will have a 4k monitor when the time comes. Plus, I just received an email yesterday about this deal. Its only 50$ over your budget and a slightly larger screen. Linus also has a review on the monitor on the LinusTechTips YouTube channel.
 http://www.bestbuy.com/site/samsung-ud590-series-28-led-4k-uhd-monitor-black/5484022.p?id=1219133600805&skuId=5484022
https://linustechtips.com/topic/295343-help-plis/#findComment-4009810
Updated.
your current gpu doesn't support 4k resolutions. However if you upgrade to a 970 definitely go 4k.
I have a 4k monitor, I still haven't encountered a game that didn't run at that resolution save extremely old games with no resolution options.
https://linustechtips.com/topic/295343-help-plis/#findComment-4011198
