auto hide tastbar issues. T^T
Solved by manikyath,
you can set yout taskbar to be on only one screen, and then drag it to wherever you want.
right click your task bar and select properties, all you need is there. (aside from the popping up, thats not configurable AFAIK)
anothertealtiger ·
Mumintroll ·
Posted in Programs, Apps and Websites3 -
ElDTac ·
HunterSVK ·
Posted in Troubleshooting2 -
Ozzi ·
Posted in Networking5 -
2
MadManMarsBar ·
Posted in Build Logs3 -
IAmAndre ·
4
play_circle_filled
Latest From ShortCircuit:
