CPU for AIO HTPC
Hey guys,
Let us think about building a cheap HTPC for about 200-300$...
Would you rather choose an Intel Pentium/Celeron or an AMD APU like an A8/A10 5xxx/6xxx?
Or would you even consider the Athlon 5350?
Thanks for your opinions on this!
EDIT:
To give you some stats:
Case with PSU: 50$
4GB DDR3 RAM: 40$
Mainboard AM1,FM2(+),1150 :50$
1TB HDD: 50$
https://linustechtips.com/topic/295167-cpu-for-aio-htpc/
The 5350 is perfect for HTPC's, you don't need an A8/A10 or something like that
RIG: I7-4790k @ 4.5GHz | MSI Z97S SLI Plus | 12GB Geil Dragon RAM 1333MHz | Gigabyte G1 Gaming GTX 970 (1550MHz core/7800MHz memory) @ +18mV(Maxed out at 1650/7800 so far) | Corsair RM750 | Samsung 840 EVO 120GB, 1TB Seagate Barracuda | Fractal Design Arc Midi R2 (Closed) | Sound Blaster Z        Getting: Noctua NH-D15 | Possible 250GB Samsung 850 Evo        Need a console killer that actually shits on every console? Here you go (No MIR/Promo)
This is why you should not get an FX CPU for ANY scenario other than rendering on a budget http://linustechtips.com/main/topic/286142-fx-8350-r9-290-psu-requirements/?p=3892901 http://linustechtips.com/main/topic/266481-an-issue-with-people-bashing-the-fx-cpus/?p=3620861
https://linustechtips.com/topic/295167-cpu-for-aio-htpc/#findComment-4007116
really? even if you'll add a discreet card?
WHy would you want a discreet card for a simple HTPC when the 5350 is an APU?
https://linustechtips.com/topic/295167-cpu-for-aio-htpc/#findComment-4007139
And what if we say that we'd like to have some more juice under the hood for, say, steamOS?
steamOS will run fine with the 5350
if you want to OC look for the Asus AM1 board as that support BLKCLK OC
Budget? Uses? Currency? Location? Operating System? Peripherals? Monitor? Use PCPartPicker wherever possible.
Quote whom you're replying to, and set option to follow your topics. Or Else we can't see your reply.
https://linustechtips.com/topic/295167-cpu-for-aio-htpc/#findComment-4007325
That's true, but what do you think when we'd like to play some browsergames in windows? Would the 5350 still have enough juice?
That's my main point, since the A10-5800k has a pretty strong GPU...
https://linustechtips.com/topic/295167-cpu-for-aio-htpc/#findComment-4007547
It certainly would. The 5350 is the best choice for this use case.
G3258 V 860k (Spoiler: G3258 wins)
i7-4790K | MSI R9 390x | Cryorig H5 | MSI Z97 Gaming 7 Motherboard | G.Skill Sniper 8gbx2 1600mhz DDR3 | Corsair 300R | WD Green 2TB 2.5" 5400RPM drive | <p>Corsair RM750 | Logitech G602 | Corsair K95 RGB | Logitech Z313
https://linustechtips.com/topic/295167-cpu-for-aio-htpc/#findComment-4007568
If you're building a complete machine it will be hard to get anything more than a AM1 platform for that price anyways. The Athlon 5350 would be the best route due to your limited budget. The APU only packs two compute units but it's still fairly acceptable for lower end gaming. If you can fit a A10-5800k into the budget it will be miles better.
https://linustechtips.com/topic/295167-cpu-for-aio-htpc/#findComment-4007586
define('miles better');
https://linustechtips.com/topic/295167-cpu-for-aio-htpc/#findComment-4007608
Here's a quick take at it.
CPU: AMD A10-5800K 3.8GHz Quad-Core Processor  ($88.75 @ OutletPC)
Motherboard: Asus A78M-A Micro ATX FM2+ Motherboard  ($54.95 @ SuperBiiz)
Case: Cougar Spike MicroATX Mini Tower Case  ($29.99 @ Mwave)
Power Supply: EVGA 400W ATX Power Supply  ($9.99 @ NCIX US)
Total: $299.55
Generated by PCPartPicker 2015-01-21 05:24 EST-0500
Much stronger CPU cores and a much stronger iGPU.
https://linustechtips.com/topic/295167-cpu-for-aio-htpc/#findComment-4007626
Memory: G.Skill Sniper Series 8GB (2 x 4GB) DDR3-2400 Memory ($65.99 @ Newegg)
Storage: Seagate Barracuda 1TB 3.5" 7200RPM Internal Hard Drive ($49.88 @ OutletPC)
Total: $299.55
A ten dollar PSU, I'm cheap, and even I would not take a swipe at that.
https://linustechtips.com/topic/295167-cpu-for-aio-htpc/#findComment-4007645
It's typically $34.99 but NCIX cut pricing down with a savings code on the product page to $24.99 plus the $15 mail in rebate drops you down to $9.99. If he wants to go over budget I would get the 600B tho the system doesn't need that much power. Meanwhile penny pinching is a must for such a low budget.
https://linustechtips.com/topic/295167-cpu-for-aio-htpc/#findComment-4007666
Total: $299.55
What I could get in my country:
ASUS AM1I-A
54.90
AMD Athlon 5350
54.90
Corsair ValueSelect 4 GB (1x, 4GB, DDR3-1333, DIMM 240)
38.80
LC-Power LC-1400mi with 200 Watt PSU
44.60
WD Caviar Blue (500GB, 3.5", Desktop)
50.80
Total
227.40
Or this build:
ASUS A78M-A
60
AMD A10-5800K
96.30
38.80
44.60
50.80
Total
290.5
https://linustechtips.com/topic/295167-cpu-for-aio-htpc/#findComment-4007676
That's exactly why PcPartPicker is basically useless if you're not living in one of the supported countries...
Mail-in rebates just don't exist in europe....
https://linustechtips.com/topic/295167-cpu-for-aio-htpc/#findComment-4007683
ASUS AM1I-A
54.90
AMD Athlon 5350
54.90
38.80
44.60
50.80
Total
227.40
Or this build:
ASUS A78M-A
60
AMD A10-5800K
96.30
38.80
44.60
50.80
Total
290.5
Do they have 2 x 2 GB kits rated at 2400 MHz? If so how much do they run. Memory frequency is all that matters when it comes to APU's and a dual channel kit is essential for boosting memory bandwidth.
Other than that the only thing I wouldn't rely on is a 200w generic PSU being reliable for such a build. Do you have a website or something that you plan on ordering from?
https://linustechtips.com/topic/295167-cpu-for-aio-htpc/#findComment-4007685
Meh on a $300 system that wouldn't pull more than 150W-200W from the wall I'd risk it. At those loads even the most wonky PSU's will deliver acceptable voltages. Only thing you'd have to worry about is build quality, it's not really a power supply that'll last you for 10 years :/
They definitely do in Belgium :P although they're not as common as they are in the US.
Desktop:     Core i7-9700K @ 5.1GHz all-core = ASRock Z390 Taichi Ultimate = 16GB HyperX Predator DDR4 @ 3600MHz = Asus ROG Strix 3060ti (non LHR) = Samsung 970 EVO 500GB M.2 SSD = ASUS PG279Q
Notebook:  Clevo P651RG-G = Core i7 6820HK = 16GB HyperX Impact DDR4 2133MHz = GTX 980M = 1080p IPS G-Sync = Samsung SM951 256GB M.2 SSD + Samsung 850 Pro 256GB SSD
https://linustechtips.com/topic/295167-cpu-for-aio-htpc/#findComment-4007699
I didn't saw any....
Fastest i saw are G.Skill Ripjaws (2x, 4GB, DDR3-1866, for 70.60)
I would mainly buy at these swiss shops:
http://www.digitec.ch
http://www.brack.ch (Got a business account there, slightly better prices)
http://www.microspot.ch
http://www.steg-electronics.ch
Prices can be easily compared at http://www.toppreise.ch
Down here in Switzerland, Mail-in doesn't exist, AFAIK it's the same in Germany.
But since we disbound the CHF from the euro, prices are falling every day ;-)
https://linustechtips.com/topic/295167-cpu-for-aio-htpc/#findComment-4007729
Hey, just remember, all us LTT members love you, no matter what CPU you choose, you're on of us. (One of us..., One of us....., one of us... *creeps forward eerily*)
https://linustechtips.com/topic/295167-cpu-for-aio-htpc/#findComment-4007764
Well, that's what my future father-in-law said when we first met...
But you guys are a part of my family too!
(Although you guys are creeps most of the time...)
https://linustechtips.com/topic/295167-cpu-for-aio-htpc/#findComment-4007786
Lol, we're creeps? O.o
Nah, I totally see that.
https://linustechtips.com/topic/295167-cpu-for-aio-htpc/#findComment-4007794
Yea memory pricing is bad. This is the cheapest 8 GB dual channel 2400 MHz kit but pushes you outside of your budget. I would recommend at least getting this instead of the single 4 GB stick that you have chosen. Later on you can add another for dual channel and double the memory bandwidth. The extra $4 a stick is worth it if you wish to be using the machine for gaming on the APU.
https://linustechtips.com/topic/295167-cpu-for-aio-htpc/#findComment-4007804
oh, i never knew that athlon 5350 was an apu..
did i get that right, htpc can be used for gaming? i've read that it is best used with graphics card for some more beef, but what difference will it make to my desktop, right?
https://linustechtips.com/topic/295167-cpu-for-aio-htpc/#findComment-4007806
ASUS AM1I-A
54.90
AMD Athlon 5350
54.90
38.80
44.60
50.80
Total
227.40
Or this build:
ASUS A78M-A
60
AMD A10-5800K
96.30
38.80
44.60
50.80
Total
290.5
What it boils down to what you want to use the machine for. If all you're using it for is video playback and some very light gaming then the Athlon 5350 will do fine and save you a few bucks. The only thing I would do is step the memory up to a 4 GB 1600 MHz stick. On the other hand the A10-5800k provides a lot more CPU and GPU grunt for the added cost. I can play Tomb Raider on my A10-6800k at normal settings which is essentially a slightly improved A10-5800k. The Athlon 5350 will be easily twice as slow in both CPU and GPU based scenarios. Tho of course it's expected due to the cost.
https://linustechtips.com/topic/295167-cpu-for-aio-htpc/#findComment-4007886
So, like everytime in IT, we can say: It depends.
It depends on what you want to do with your build.
If you want to playback videos or use it as a mediacenter, the cheapest option (Athlon 5350) will do fine.
If you want to play some games with it, go with an A10 APU (Favorable the 5800K, since it's 5~10% slower than 6800K but a lot cheaper).
If you really want to play games at high settings with the machine, go with either an i3 or i5 (budget option is 860K, awesome little chip!) and get a decent GPU like AMDs R9 series as well as the R7 260x and R7 265. Additionally, you'll need at least 8 gigs of RAM.
Thanks for your comments so far!
https://linustechtips.com/topic/295167-cpu-for-aio-htpc/#findComment-4008111
