Hello ladies and gentlemen of the internet, KenMicMarKey here, and I'm slightly new to the community.
With that out of the way, I have a question: What are your thoughts on hybrid storage drives? What are the pros and cons? And most importantly, is there a more efficient solution to a hybrid drive without spending any more money?
I intend to purchase one for my new gaming PC build, and I'm not quite ready to take the leap and commit to having multiple storage devices in the same system. I like to keep things simple. The item I had in mind is a Seagate 1TB 3.5' 7200RPM Hybrid Internal Hard Drive. From what I understand, it's a standard 1TB HDD from Seagate, but with a 7.8GB SSD for cache.
Here's a link to the item in question: http://pcpartpicker.com/part/seagate-internal-hard-drive-st1000dx001
All thoughts and answers are welcome, and I look forward to seeing what this community has to say!
https://linustechtips.com/topic/294770-hybrid-storage/
SSHD is only good if you are on very limited budget. SSD is faster still. But it is definitely not bad.
Storage: Sandisk Ultra Plus 128GB 2.5" Solid State Drive  ($53.99 @ NCIX US)
Total: $103.87
Generated by PCPartPicker 2015-01-20 13:52 EST-0500
Something like this is better value.
https://linustechtips.com/topic/294770-hybrid-storage/#findComment-4002010
meh is the best word to describe it, youre better off with an SSD and a seperate HD
ITX Monster: CPU: I5 4690K GPU: MSI 970 4G Mobo: Asus Formula VI Impact RAM: Kingston 8 GB 1600MHz PSU: Corsair RM 650 SSD: Crucial MX100 512 GB HDD: laptop drive 1TB Keyboard: logitech G710+ Mouse: Steelseries Rival Monitor: LG IPS 23" Case: Corsair 250D Cooling: H100i
Mobile: Phone: Broken HTC One (M7) Totaly Broken OnePlus ONE Samsung S6 32GB  :wub:  Tablet: Google Nexus 7 2013 edition
https://linustechtips.com/topic/294770-hybrid-storage/#findComment-4002018
Here's a cheap ass version if you don't want to invest into a SSD now but maybe want to get a small one later:
when installing windows, creatw two partitions. One with ~120 GB storage, the other one with the rest. Treat that 120 GB partition like your SSD and converting to the SSD will be a charm. Just use a cloning utlility, some SSDs even provide a trial of Acronis or sth. like that.
Another handy trick to divide your stuff on two partitions is on every program/game installation you just change the C:\ to a D:\ and leave all the rest the same. All the folders will be created normally jsut on your 2nd drive.
Edit: use a regular HDD for this of course.
who cares...
https://linustechtips.com/topic/294770-hybrid-storage/#findComment-4002067
Hybrid drives make sense for something like a laptop that can only handle one physical drive.  You get most of the speed of an SSD and then a TB or so of HDD-grade storage.
At this point, Hybrid drives make very little sense in your desktop.
 - you have space for multiple drives
 - when you fill up the Hybrid drive, you are going to need another drive anyway.
 - having your OS on the same drive as all of your data will lead to regrets.
 - 120GB SSDs and 1TB HDDs are relatively inexpensive.
https://linustechtips.com/topic/294770-hybrid-storage/#findComment-4002149
