I'd go coolermaster V650 instead
CPU: i5-4690k GPU: 280x Toxic PSU: Coolermaster V750 Motherboard: Z97X-SOC RAM: Ripjaws 1x8 1600mhz Case: Corsair 750D HDD: WD Blue 1TB
How to Build A PC|Windows 10 Review Follow the CoC and don't be a scrub~soaringchicken
Thanks, any other tips for cutting the price down without losing performance?
What's the system being used for?
Gaming 3d modeling and watching anime as well as being a computer.
What kind of 3d modeling?
Me and some friends are making a game, and I'm going to go to college for the art side of games.
http://prntscr.com/5v4fqb <- What I was working on.
Better: http://pcpartpicker.com/p/YB6xNG
I googled if Blender (I'm assuming that is the 3D modelling tool used) benefits from hyper threading and quick/old results suggest that it does so very much.
So I'd suggest staying with the i7 CPU.
I do like your find with the R9 290 instead of the R9 280X for practically the same price!
Considering that this machine will be in heavy use, I do think that going for gold efficiency is warranted.
This EVGA PSU is well below the original option in price, while keeping the same efficiency rating and featuring full modularity.
Yes, Blender can benefit from HT but not so much when the extra threads aren't needed.
Getting a larger psu would lower efficiency and partially negate the point of getting a higher efficiency psu in the first place. It's also not worth paying $35 more for.
Yes it's Blender, what's the difference in gold rating and bronzes?
I have yet to find a modeller who complains about having head room when it comes to performance, especially when the have to render somethign out.
Considering the markup is pretty much on par with the gain in performance, it makes sense.
About the PSU: Efficiency does not necessarily have to drop. Remember, it follows a bell curve and is actually most efficient when around the 50% mark (please don't quote me on the exact number)
So, higher capacity + higher rating should result in better efficiency.
A 4690k is already more than enough headroom. There isn't much rendering to be done for game modeling.
Due to how a system is actually used and not running at full load 24/7, a larger than needed psu will generally result in worse efficiency.
