Hello everyone, I live in the America and my goal is to successfully put together and build a pretty decent gaming pc, I only plan to run one monitor for now and I'm upgrading because its just time to put the ol toaster to rest "My Current Pc". I already put some things together but due to my lack of knowledge i would like to post my build here and get a few "second opinions" or any advice or ideas on better parts. On a side note if anyone could either tell me or point me in the right direction i would like to know how many 120 mm fans vs 140 mm fans i should put in this case and more importantly where should i put them for the best cooling results.
**CPU** | [intel Core i5-4460 3.2GHz Quad-Core Processor](http://pcpartpicker.com/part/intel-cpu-bx80646i54460) | $179.98 @ OutletPC
**CPU Cooler** | [Noctua NH-D15 82.5 CFM CPU Cooler](http://pcpartpicker.com/part/noctua-cpu-cooler-nhd15) | $89.98 @ OutletPC
**Motherboard** | [MSI Z87-G41 PC Mate ATX LGA1150 Motherboard](http://pcpartpicker.com/part/msi-motherboard-z87g41pcmate) | $111.98 @ Newegg
**Memory** | [G.Skill Ripjaws X Series 16GB (2 x 8GB) DDR3-1600 Memory](http://pcpartpicker.com/part/gskill-memory-f31600c9d16gxm) | $119.99 @ Newegg
**Storage** | [intel 730 Series 240GB 2.5" Solid State Drive](http://pcpartpicker.com/part/intel-internal-hard-drive-ssdsc2bp240g4r5) | $160.98 @ Newegg
**Video Card** | [EVGA GeForce GTX 970 4GB SSC ACX 2.0 Video Card](http://pcpartpicker.com/part/evga-video-card-04gp43975kr) | $349.98 @ NCIX US
**Case** | [Phanteks Enthoo Pro ATX Full Tower Case](http://pcpartpicker.com/part/phanteks-case-phes614pbk) | $99.99 @ Amazon
**Power Supply** | [Corsair CX 750W 80+ Bronze Certified Semi-Modular ATX Power Supply](http://pcpartpicker.com/part/corsair-power-supply-cx750m) | $59.99 @ Newegg
**Optical Drive** | [Asus DRW-24B1ST/BLK/B/AS DVD/CD Writer](http://pcpartpicker.com/part/asus-optical-drive-drw24b1stblkbas) | $18.75 @ OutletPC
https://linustechtips.com/topic/294466-first-build/
Good, but use pcpartpicker. And why do you want 16gb of RAM?
CPU: i5-4690k GPU: 280x Toxic PSU: Coolermaster V750 Motherboard: Z97X-SOC RAM: Ripjaws 1x8 1600mhz Case: Corsair 750D HDD: WD Blue 1TB
How to Build A PC|Windows 10 Review Follow the CoC and don't be a scrub~soaringchicken
https://linustechtips.com/topic/294466-first-build/#findComment-3998566
change:
mobo: unless youre getting a haswell "pre-refresh" chip like the 4670k or 4770k, then change the mobo to an H97 board or something of the sort if you plan to stick with the locked cpu.
storage: do you already have a mass storage drive? ssd's fill up hella quick, wont last you long with games taking up 40-50 gigs on average.
ram: more than 8 gigs will not really benefit you in games, so you could save some money there
psu: for a few bucks more, try and pick up and evga 80+ gold power supply.
other than that, youve got a nice build.
https://linustechtips.com/topic/294466-first-build/#findComment-3998613
First off i wanted to say thank you to everyone that posted and As far as the choice of 16 gigs of ram, i wanted to get 16 gig's because i plan on doing a lot of recording and streaming when i get this pc built, But again if you guys don't think its necessary or perhaps i waste of money then i can always kick down to 8 gigs. I also wasn't aware that the CPU i picked out was locked and i will switch it out with the 4670k thank you for the suggestion! Oh and as far as the power supply goes i just wanted to get something in a higher wattage just in case i want a bigger card or something down the line.
https://linustechtips.com/topic/294466-first-build/#findComment-3998703
