ok i do occasional computer repair work !
so last time a guy called me saying his laptop was not starting  and then i told him to remove the battery and run it ... and it worked ! after that with battery as well !
after few hours he called me saying display is not working so i told him ill come and check i went and checked it ram was faulty so i changed it and it  worked !
and after a month now he called me again saying the laptop is not working ... it only works when he removes the battery !
and when he does that the mouse does not work !
any ideas what could be wrong ? cause i do not have a clue ! and i need to go see it tomorrow...
he bought that laptop it was pre owned ! and was not even 12 months old has windows 7 in it !
Thanks for reading i appreciate ur help !
CPU: Fx 8350 | CPU Cooler: Coolermaster Hyper 212 Evo Now  AMD STOCK CPU COOLER | Motherboard: Gigabyte GA-970A-DS3 (rev 1.1)   NOW MSI 990FXA-GD80 | Ram: Corsair Vengence 8GB DDR3 Motherboard detects 7gb for some weird reason | Graphics Card: SAPPHIRE HD 7870 GHz Edition 2GB GDDR5 |  HDD: 1 TB samsung
Case: CM elite 310 | Monitor: Aoc e2050S
OS: Windows 8 Professional 64 Bit NOW  Wndows 10 Professional 64 Bit
 Power Supply: Cooler Master Thunder 500W NOW GX 650W v2
https://linustechtips.com/topic/293961-laptop-trouble-need-help/
What laptop is this?
well it was a month ago so i do not remember the model no but what i can tell u is its from hp and has i3 and 2gb ram sorry but that's all i remember
https://linustechtips.com/topic/293961-laptop-trouble-need-help/#findComment-3991133
The model number is pretty important if we're going to try to help you, apart from giving vague advice.
Sig under construction.
https://linustechtips.com/topic/293961-laptop-trouble-need-help/#findComment-3991141
well the guy called me i do not have his no it was on landline >.> so i dont know how i can tell u model but i would appreciate any advice ... also ill post model no here asap i see it
https://linustechtips.com/topic/293961-laptop-trouble-need-help/#findComment-3991149
The first thing that comes to mind is a faulty battery.
yeah but that would not explain why the mouse is not working without battery
https://linustechtips.com/topic/293961-laptop-trouble-need-help/#findComment-3992770
any thing guys ?
https://linustechtips.com/topic/293961-laptop-trouble-need-help/#findComment-4000454
