i saw linus putting thermal paste like a grain of rice
But i say JayzTwoCents putting thermal paste in a star method
But the method of putting thermal paster matters?
Leave your comments down below and il see ya next time :3
not really, but considering that intel CPUs have a die that is taller than it is wide, I do a thin vertical line for enough coverage for the hottest parts of the Heat spreader, but will still result in a thin amount especially with high mounting pressure.
edit: 1111 posts
Different methods for different dies (e.g. Haswell may require a small line, instead of a small pea shape).
I have been a fan of the pea shaped method for ever.
Asus Z77 Sabertooth, Intel Core i5 3570k 4.2 GHz, EVGA GTX 780, Corsair Vengeance 16Gb ,
Samsung EVO 250&500Gb, Western Digital Black 2TB,  Corsair RM 750
Custom Water Loop
CPU Block Koolance 380iGPU Block EKWB Clean CSQPump Laing DDC w/ EKWB X-RES 100Radiatiors NexXxoS Monsta 240 & Swiftech 240x35Tubing PrimoChill Primoflex Advanced LRT Elegant White 3/8" ID 5/8" ODFittings White Monsoon Free Centre Compression Fittings 3/8" ID 5/8" ODFans6x Noctua NF-F12 w/Noctua LNA Adaptors
But does your method our method affects the performance?
I would say it impacts it less than using a good material and less than using either too much or too little.
Corsair 400C- Intel i7 6700- Gigabyte Gaming 6- GTX 1080 Founders Ed. - Intel 530 120GB + 2xWD 1TB + Adata 610 256GB- 16GB 2400MHz G.Skill- Evga G2 650 PSU- Corsair H110- ASUS PB278Q- Dell u2412m- Logitech G710+ - Logitech g700 - Sennheiser PC350 SE/598se
Is it just me or is Grammar slowly becoming extinct on LTT?
a small pea sized under the pressure of the heat sink is gonna cover the whole chip pretty much anyway
                     ¸„»°'´¸„»°'´ Vorticalbox `'°«„¸`'°«„¸
`'°«„¸¸„»°'´¸„»°'´`'°«„¸Scientia Potentia est  ¸„»°'´`'°«„¸`'°«„¸¸„»°'´
Main Rig:-
Server:-
Method always matters.
That said, you have to consider what thermal paste actually does: it facilitates the transfer of heat between the CPU and your cooler.  Chances are the natural spreading of the paste due to the pressure of the heatsink being mounted to it is more than sufficient and you'll receive damn near uniform coverage anyway.
4K // R5 3600 // RTX2080Ti
when i did the line method i somehow got an air bubble... so i will only go with pea method.
Edit: bubble, more like air pocket.
Cpu: Intel i7-5930k Mobo: Asus Rampage V Extreme Ram: G.skill Ripjaws 4 4x4gb 2666mhz Gpu: Gigabyte GTX 970 G1 Gaming
PSU: Evga Supernova G2 850W Storage: Samsung 850 Pro SSD 512gb Case: Phanteks P400S CPUcooler: Corsair H110 OS: Win 8.1
