RAM help!
Go to solution Solved by AlwaysFSX,
If you really want to be sure, just match the timings and voltage, speed too if it's a faster kit, and just get something that matches those. Mixing ram works perfectly fine. Doesn't have to be the exact same model and brand to work.
https://linustechtips.com/topic/293861-ram-help/#findComment-3989721
