Network constantly disconnecting for a few seconds
Hey guys,
my internet keeps cutting out. I get the 2kgnfHz.png for 3-5 seconds, then its back. But it does it ALL. THE. TIME. and it is annoying as f*ck.
It happens once every 10-20 seconds, then it stops happening for a few days, then its back. Today its really bad.
I've already contacted my ISP and they say its not the connection to my house, so it must be either the router or my PC.
Does anyone know what could be causing this? Router firmware and networking drivers are up to date.
Already did that, didn't help, sadly.
Very strange, have you installed any new programs recently? Try running Anti Virus, something might have creeped its way onto your computer and decided to start messing with it.
I've ran both Avast and Malwarebytes several times with no results. This issue has been coming and going for several months now, so I wouldn't be able to point at any specific software that started the issue.
maybe hardware problem
1. try a different port on your router
2. check if other systems have the same problem
if your router is fine, then I'm guessing your system's NIC is broken
Yes I have tried different ports, but that doesn't prove that the router is fine. I had issues restarting it the other day, it wouldn't start up to the point where I could access it and I had to try 3 times before it came back online. As for the NIC, do you know any way of diagnosing problems with it? I'm not willing to buy a brand new motherboard just to find out my NIC was fine  :mellow:
you can try a usb/pci to ethernet adapter. For example: http://www.ncix.com/detail/linksys-usb3gig-usb-3-0-to-eb-98983-1261.htm
but unfortunately there is no way to know for sure if NIC is the problem, so you might be wasting money.
Good idea.
Try a different router with a different ethernet cable?
 [spoiler=CORMAC]CPU:Intel celeron 1.6ghz RAM:Kingston 400mhz 1.99gb MOBO:MSI G31TM-P21 GPU:Will add one later on! CASE:local ROUTER D-Link 2750U, D-LINK 2730U MOUSE:HP,DELL,ViP KEYBOARD: v7 SPEAKERS:Creative 245  MONITOR:AOC E970Sw HEADSET: Sony MDRx05s UPS:conex ups avr 500va PSU:idk OD:Samsung super writemaster STORAGE:80 gb seagate+ Seagate 1TB OS:Windows xp sp3 themed to Windows 7 + Linux |Rest all pc in my house will be updated from time-time
COMING SOON
