This is my first pc build, i want it to be light weight gaming, i want to go with AMD
These are the two builds i came up with, both based off:-
https://www.youtube.com/watch?v=sWans5FU4cU
Please review and suggest which one i should go with:-
1) http://uk.pcpartpicker.com/p/Cxy8mG
2) http://uk.pcpartpicker.com/p/rcdMD3
I do want to overclock to 4.5ghz
https://linustechtips.com/topic/293343-first-pc/
the 2nd one i think that cpu is good aswell
My Personal PC 'Apex' https://uk.pcpartpicker.com/user/LiamBetts123/saved/3rTNnQ
Intel Core i9 9900k, ASUS Z390-A, RTX 2080TI, Meshify C, HX 850i, 32GB Gskill Trident Z RGB @ 3200MHZ, 500GB NVME, 500GB SSD & 2 x 4TB Baracudas
1
https://linustechtips.com/topic/293343-first-pc/#findComment-3983065
2nd, but please, for the love of god, get the G3258 and the Z97 PC Mate board, APUs are crap when it comes to gaming
Scarlet KnightIntel Core i3 6100 || Antec A40 Pro CPU Cooler || MSI Z170A Gaming M5 || Kingston HyperX 16GB DDR4-2133MHz || Samsung 850 Evo 120GB || Seagate Barracuda 1TB || Gigabyte G1 Gaming R9 390X 8GB || Seasonic M12II 620W || In Win 503 || Corsair Strafe || Steelseries Kinzu V3 MSI Edition || Dell UltraSharp U2414H || Xiaomi Alumunium Mouse Pad (S)
#Gadget:
Phone: BlackBerry Classic Q20, Samsung Galaxy Note 4 S-LTE SM-N916S
Console: PlayStation 4 500GB CUH-1206A
Tablet: iPad Air 2 16GB Wi-fi Only
Laptop: MSI GE62 (i7 4720HQ || 8GB DDR3 || NVIDIA GTX960M || Samsung 650 EVO 120GB + 1TB HDD)
In-ear Monitor: Xiaomi Piston 3.0
https://linustechtips.com/topic/293343-first-pc/#findComment-3983075
Problem with that is i need a quad core, and want overclock,
Why would you want a Quad Core?
Pentium G3258 CAN overclock by the way.
Laptop - Asus TUF FX504GM
i7 8750H | 24GB DDR4 | GTX 1060 6GB | 128GB NVMe SSD | 1TB HDD
Peripherals
Logitech G102 Prodigy | Nubwo N12
https://linustechtips.com/topic/293343-first-pc/#findComment-3983112
I know the pentium can over clock
I've been told that i need a quad core as i'm gaming for things like watchdogs
this was the build i was told to do first
http://uk.pcpartpicker.com/p/QhnXZL
https://linustechtips.com/topic/293343-first-pc/#findComment-3983118
1. G3258 is overclockable
2. G3258's gaming performance is even better than the FX 6300, which is a 6-core, let alone APU
3. G3258 has lesser TDP, so heat will definitely not an issue compare to AMD
In short, if you game, get intel, quadcore from AMD is just a gimmick, don't fall for it
#Gadget:
https://linustechtips.com/topic/293343-first-pc/#findComment-3983119
Don't most games need quad core now??
How is this build?
http://uk.pcpartpicker.com/p/PLvsWZ
https://linustechtips.com/topic/293343-first-pc/#findComment-3983127
Light gaming don't need quad core, they need a strong, single core, not 4 weak cores
Also, please don't put your faith in system requirement all the time, some of them are full of shit anyway
#Gadget:
https://linustechtips.com/topic/293343-first-pc/#findComment-3983153
I'm really new to this, i want to play games like left for dead 2, and stuff like that watchdogs is one i really want to, also what chipset do i go for? if it better to get matx instead of itx and get like a stacker 915f and know i can add more later?
https://linustechtips.com/topic/293343-first-pc/#findComment-3983172
That's actually a fairly solid budget build you've made. But why don't we get something clear.
What's your actual budget atm?
Peripherals
https://linustechtips.com/topic/293343-first-pc/#findComment-3983185
1. If you want MATX go for G3258 and H81 chipset
2. A G3258 and 270 will put you to near max setting with light AA on L4D2, not quite sure about WD though, it runs like crap on AMD gpu
3. It will be better to get MATX instead of ITX for better airflow in the case so I'd recommend it, case depends on your preferance, but try not to overspend on it
#Gadget:
https://linustechtips.com/topic/293343-first-pc/#findComment-3983196
 Can i rebuild with a matx and get you to review.
I thought i need z97/z99 to overclock to the like 4.5ghz this can achieve?
https://linustechtips.com/topic/293343-first-pc/#findComment-3983207
Yes, build it and I'll check
I have seen many people OCing their G3258 using H81 at 4.5 GHz, even in our forums, Z97 more expensive but provides better oc limit though
#Gadget:
https://linustechtips.com/topic/293343-first-pc/#findComment-3983270
Will i be able to update to something like an I5 later with the H81? Also what Brand i've looked on PC part Picker and they have some H81 for like £90 but i know this prbably wont be good enough so what do i choose?
See this would have been my go to
http://www.scan.co.uk/products/gigabyte-ga-z97p-d3-intel-z97-s1150-ddr3-pcie-30-(x16)-2-way-crossfirex-hdmi-atx
https://linustechtips.com/topic/293343-first-pc/#findComment-3983283
Technically you can upgrade up to an i7
Look for Asus, MSI, some of their H81 boards are quite cheap, if you loosen your budget more you can even look for Asrock H97M Pro as they are dirt cheap and supports AMD crossfire
#Gadget:
https://linustechtips.com/topic/293343-first-pc/#findComment-3983313
Please review this build
I'd like to do watercooling with the H60/H80i is it worth it? and would you suggest a better case?
http://uk.pcpartpicker.com/p/bRpDK8
If i had used a minit itx now i would have used the stacker 915F because i could add a 915R for watercooled or 935 for a big upgrade
https://linustechtips.com/topic/293343-first-pc/#findComment-3983352
It's not worth doing watercooling on a budget build, that air cooler is good and will do just fine
Also, I see that you choose a 200R, spend on a cheap Z97 like MSI PC Mate would be better because it allows for upcoming cou upgrade should you need
Also I'd hold my wallet for the GPU for now, GTX960's release is around the corner, and they will pretty much has the same price as the 760, if you can stretch your budget, though
#Gadget:
https://linustechtips.com/topic/293343-first-pc/#findComment-3983458
Would you chose that case?
And this is the current build,
http://uk.pcpartpicker.com/p/Vv8Pcf
I would prefer nvidia as i will be playing steam and steam os is a maybe (got it installed on a 2.5 500gb external drive from a friend who put a ssd in to replace it)
currently it comes it at £455, so if we stick to the 200r we could have £165 - £200 on gpu what would you suggest?
https://linustechtips.com/topic/293343-first-pc/#findComment-3983484
That's the case I'm using and I highly recommend it, feels sturdy with the steel chassis and whole lot of room for air flow and cable management
I suggest the GTX960 for that price range, of course when it is released
he got these results
sorry about the solved hit the wrong button :(
Simple, his cpu is bottlenecking
#Gadget:
https://linustechtips.com/topic/293343-first-pc/#findComment-3983552
His is not over clocked though so that will make a difference,
What overclock can i expect with the 212 evo, or is there a better option, i'd like 4ghz+
I've looked on 3x systems they use a asus h81 board, however think i'll stick with the msi z97 so i can add an i5 4670k later if i so wish
https://linustechtips.com/topic/293343-first-pc/#findComment-3983580
Aso quick question if i streched my budget for a quad core would a i5 4440 be better than g3258? or is the 4690k the best next step up? or is the appropriate i3?
https://linustechtips.com/topic/293343-first-pc/#findComment-3983643
