so i was looking to get the zotac amp extreme 970 but will it fit in the bit fenix pandora with out any problems? please help
In terms of length, yes it will fit. But the zotac card has that bulge on the side. Judging from the case pic, I doubt it will fit.
Edit: It's going to be a VERY tight fit.
Project Depravity: £850 / ????? (03/12/2015) Case: Phanteks Enthoo Primo SE Red Keyboard: Corsair K95 RGB MX Red Monitors: 3* Asus PG279Q Stand: Ergotech Triple Desk Stand Webcam: Logitch C920
RIP in kill: CPU: Single core Celeron M @1.73GHz RAM: 1GB (512MB x2) DDR2 SO-DIMM Motherboard: Asus MOCA-AR HDD: 160GB SATA2 5400rpm
Current System: CPU: Intel i5-4690K Cooler: Cooler Master Hyper 212 EVO Motherboard: MSI Z97 Gaming 5 RAM: Kingston HyperX Fury 8GB 1866MHz GPU: Gigabyte Windforce 960 4GB SSD: Sandisk Ultra Plus 128GB HDD: WD Caviar Blue 1TB PSU: Corsair CX500M Case: Corsair 200R Windowed MonitorLG 22MP55HQ 22" IPS + HP w19 MouseRoccat Savu Keyboard: Corsair Raptor K30 Mouse Pad: Perixx DX-1000XXL Headset: Kingston HyperX Cloud OS: Windows 10 Pro 64-bit
https://linustechtips.com/topic/293338-will-it-fit/#findComment-3982975
Don't get the AMP, Steve from gamersnexus bashed the shit out of it.
  ﷲ   Muslim Member  ﷲ
KennyS and ScreaM are my role models in CSGO.
CPU: i3-4130 Motherboard: Gigabyte H81M-S2PH RAM: 8GB Kingston hyperx fury HDD: WD caviar black 1TB GPU: MSI 750TI twin frozr II Case: Aerocool Xpredator X3 PSU: Corsair RM650
https://linustechtips.com/topic/293338-will-it-fit/#findComment-3982996
Gonna be very tight on the sides considering Zotac added a huge yet unimportant bulge on their extreme cards.
Don't you have other 970 options?
Laptop - Asus TUF FX504GM
i7 8750H | 24GB DDR4 | GTX 1060 6GB | 128GB NVMe SSD | 1TB HDD
Peripherals
Logitech G102 Prodigy | Nubwo N12
https://linustechtips.com/topic/293338-will-it-fit/#findComment-3983007
well i was watching all the reviews of it and they says its a beast card and such
The gigabyte G1 would be a much better alternative. It's quieter, performs just as good and looks so much smexier.
https://linustechtips.com/topic/293338-will-it-fit/#findComment-3983074
They pretty much say that on all 970s really.
Gigabyte G1 or EVGA are the brands I'd go with. Slightly cheaper, cooler, quieter and better overall.
EDIT: And they'd fit that case no problemo.
Peripherals
https://linustechtips.com/topic/293338-will-it-fit/#findComment-3983093
