Yea i though i had that on the first motherboard i had so i sent it back and got it replaced but the new motherboard just has the same problem
Can we get full system specs?
Do you mean you replaced the cable, the motherboard, or both?
sudo chmod -R 000 /*
https://linustechtips.com/topic/292840-vga-max-resolution/#findComment-3976690
a8 6600k, gigabyte ga-f2a88xm-ds2, zalman 500w, 8gb kingston 1600mhz beast ram.
I got the motherboard replaced and i have tried it with more than one cable
https://linustechtips.com/topic/292840-vga-max-resolution/#findComment-3976710
I know VGA can go up to at least 1920x1080, so it's not the VGA that's at fault.
2048×1536@85Hz actually.
https://linustechtips.com/topic/292840-vga-max-resolution/#findComment-3976713
are you sure that your GPU support that resolution via VGA?
Also if you can plug it in DVI why would you want to use VGA?
 I dont have a GPU only a APU so i have to plugged it into the motherboard and i have 2 monitors so one with DVI and one with VGA
https://linustechtips.com/topic/292840-vga-max-resolution/#findComment-3976721
does the monitor work fine with the dvi cable?
https://linustechtips.com/topic/292840-vga-max-resolution/#findComment-3976722
I have a 1600x900 monitor plugged into the VGA post on the back of my motherboard as well as a DVI one. The DVI works fine but the VGA will only work a 1440x900. Why is that, because VGA max resolution should be 1080x1200.
Thanks
it should be 2048x1536.
My Rig: AMD Ryzen 5800x3D | Scythe Fuma 2 | RX6600XT Red Devil | B550M Steel Legend | Fury Renegade 32GB 3600MTs | 980 Pro Gen4 - RAID0 - Kingston A400 480GB x2 RAID1 - Seagate Barracuda 1TB x2 | Fractal Design Integra M 650W | InWin 103 | Mic. - SM57 | Headphones - Sony MDR-1A | Keyboard - Roccat Vulcan 100 AIMO | Mouse - Steelseries Rival 310 | Monitor - Dell S3422DWG
https://linustechtips.com/topic/292840-vga-max-resolution/#findComment-3977206
Where did you get that number? Every source tells me it's 1920x1200 at 60 Hz?
http://en.wikipedia.org/wiki/VGA_connector
There are no monitors at that res so I guess it doesn't really matter.
https://linustechtips.com/topic/292840-vga-max-resolution/#findComment-3977272
