Hello, and thanks for reading this already!
I'm looking for a quiet, but of course good, cpu cooling.
It can be liquid or heatsink, but if heatsink preferably not a giant 20 cm thing, just a low profile one :-)
Any good suggestions?
Thanks in advance!
Basic guide to CPU's!
If I said I were 14, you would call me a kid. If I say 70, you’ll entitle me too old. If I say 20 you say I’m inexperienced and if I say 40 than I'm too boring.
龴 ͡ↀ ◡ ͡ↀ龴#locked( ͡͡ ° ͜ ʖ ͡ °)
https://linustechtips.com/topic/292246-quiet-cpu-cooling/
Of course if you're on a budget, the Hyper 212 Evo/T4 is a great choice.
For low profile, this is a good one:
http://www.newegg.ca/Product/Product.aspx?Item=N82E16835608019
For liquid this is also a very good cooler, especially for the price
http://www.newegg.ca/Product/Product.aspx?Item=N82E16835103181
Of course theres many more, but those are what I would recommend! :)
https://linustechtips.com/topic/292246-quiet-cpu-cooling/#findComment-3969527
budget?
Arround € 100 (115 $ // 76£) would be nice!
Will you be overclocking? What cpu?
I'll be using the Intel i5-4670K (Socket: LGA1150)
And i'm planning to eventually overclock, but not for a couple of months after purchase :)
Side question, is a double fan liquid cooler much better than a single fan liquid cooler?
https://linustechtips.com/topic/292246-quiet-cpu-cooling/#findComment-3973356
for a hundred your beat bet is either a dark pro 3 or an nh d14
https://linustechtips.com/topic/292246-quiet-cpu-cooling/#findComment-3974809
They vary with radiator thickness, fin density and fans. For quiet operation you should go with the biggest fans that you can.
https://linustechtips.com/topic/292246-quiet-cpu-cooling/#findComment-3974848
What do you mean by low-profile?
Where are you shopping?
https://linustechtips.com/topic/292246-quiet-cpu-cooling/#findComment-3975962
With low-profile i mean not too big of size, and also quiet!
Thanks, I'll check them out!
That's a very good tip, I'll remember that! Thanks!
https://linustechtips.com/topic/292246-quiet-cpu-cooling/#findComment-3977335
But what does that mean..? What height?
https://linustechtips.com/topic/292246-quiet-cpu-cooling/#findComment-3977351
Sorry that I'm a little bit inspecific :P
I'm going to be using the Corsair Air 540, which has a limited CPU cooler height of 170mm
Also, my country of shipping is Belgium, but surrounding countries often ship here (amazon.de and amazon.fr for example)
https://linustechtips.com/topic/292246-quiet-cpu-cooling/#findComment-3977476
170mm is enough for almost any air cooler. You could get a Shadow Rock 2: http://www.amazon.de/quiet-BK013-Shadow-CPU-K%C3%BChler-4-polig/dp/B00DQCOJUQ/ref=sr_1_19?s=computers&ie=UTF8&qid=1421533442&sr=1-19&keywords=bequiet
https://linustechtips.com/topic/292246-quiet-cpu-cooling/#findComment-3977558
