My computer HDD is becoming wierd. It seems to be running extremely slow. When i did a benchmark, i get aroun 1.2 MB/s on the C drive. On the D: drive i still get around 50 MB/s even though it's just another partition. My computer is not even one year old, and i have tried to defragment and everything, but i couldt defragment because it was only at like 2% after one whole night.
https://linustechtips.com/topic/291599-hdd-problems/
check if your PC has any virus using Malwarebytes or AVG
Budget? Uses? Currency? Location? Operating System? Peripherals? Monitor? Use PCPartPicker wherever possible.
Quote whom you're replying to, and set option to follow your topics. Or Else we can't see your reply.
https://linustechtips.com/topic/291599-hdd-problems/#findComment-3962426
I have checked for malware, and i haven't got anything, reset my computer recently, and didn't help
when you benchmark your disk
does it show anything red or alert or warning?
https://linustechtips.com/topic/291599-hdd-problems/#findComment-3965347
Try using a full HDD diagnostic tool, not just the "Health Checker" in Defraggler. Seagate Seatools and WD Data Lifeguard are great options.
CompTIA A+ Certified
"We are all cups, quietly and constantly being filled. The trick is knowing how to tip yourself and let the good things pour out." - Ray Bradbury
https://linustechtips.com/topic/291599-hdd-problems/#findComment-3969919
