Well this is basically telling you that you're not allowed to do that, so i would change back.
"Blue" screens NEVER lie :)
Intel i7-2600K @ 4,5GHz | EVGA GeForce GTX 780 w/EKWB Copper Waterblock | Kingston HyperX blu 16GB @ 1600 MHz | Phanteks Enthoo Primo | MSI Z77A-GD65 | CM M1000 Silent Pro | Samsung 840 Pro 128GB | BenQ XL2420T 120hz | Logitech G710+ | Razer Deathadder 2013 -
- XSPC Raystorm CPU Waterblock | XSPC RX360 Radiator | EKWB EK-FC Titan GPU Waterblock -
https://linustechtips.com/topic/29150-ga-z77x-up4-th-problem/#findComment-370715
try flashing to the latest bios?
Mainboard Asrock Z170 OCF CPU 6700k RAM Tridentz 3600 HDD Intel 730 240gb GPU GTX 780ti sc acx PSU Silverstone Strider 1200W  Case Antec 900 Laptop Lenovo Thinkpad T520 build log-   http://linustechtips.com/main/topic/35809-antec-900-the-re-birth-of-a-legend/ Check out the Tech Center https://www.youtube.com/user/prokon24/videos LTT's Unicore King
https://linustechtips.com/topic/29150-ga-z77x-up4-th-problem/#findComment-370751
Some things may work fine on-screen and with some programs but the Bios normally know what is safe and what it SHOULD run at and sometimes you've reached the max so it won't let you.
https://linustechtips.com/topic/29150-ga-z77x-up4-th-problem/#findComment-370764
your trying to overclock?
it boots fine at default settings?
https://linustechtips.com/topic/29150-ga-z77x-up4-th-problem/#findComment-370786
It boots fine sometimes in default settings.. sometimes I need to press the power/reset button several times to boot it
Actually before I manage to OC it to 4.5ghz for 2 weeks without any problems.. I just OC it for benchmark purposes and running now on stock for almost 2 months
https://linustechtips.com/topic/29150-ga-z77x-up4-th-problem/#findComment-370794
disable xmp
manually input your stock memory frequency,timings and voltage.
i see your BCLK is set at 99.79. did you do that? set it for 100.
you need to figure out if you can run fine at stock settings before you even think of overclocking.
https://linustechtips.com/topic/29150-ga-z77x-up4-th-problem/#findComment-370807
disable xmp
I tried your suggestion same thing happen again
I just took this photo a minute ago before turning back here
https://linustechtips.com/topic/29150-ga-z77x-up4-th-problem/#findComment-370861
i5 3570k?
https://linustechtips.com/topic/29150-ga-z77x-up4-th-problem/#findComment-370870
what is your cpu?
you should see if maybe you have a bad stick of ram, but thats not likely if you are able to prime once you do boot. possibly try booting with only one stick of ram. try either stick one at a time in  all slots.
does your board have a dual bios?
you could always try an older bios revision.
https://linustechtips.com/topic/29150-ga-z77x-up4-th-problem/#findComment-370895
Actually this is kinda weird because my system won't boot in a single mems..I need to put all the 4 sticks to boot it..
btw, heres my system specs
CPU: i5 3570k
MOBO: GIGABYTE Z77X-UP4 TH
GPU: MSI GTX 660Ti Power Edition
COOLER:NZXT x60 Kraken
SSD: Plextor PX-M2P 256GB
HDD: Hitachi 1TB and Seagate 500gb
RAM: Crucial Ballistix Tactical Tracer DDR3-1866 16GB
PSU: Be Quiet! Dark Power Pro 10 550w
https://linustechtips.com/topic/29150-ga-z77x-up4-th-problem/#findComment-370919
CPU: i5 3570k
sounds like a memory issue, most likely with the board. you should be able to boot with 1-2-3 or 4 sticks of ram. especially with just one.
https://linustechtips.com/topic/29150-ga-z77x-up4-th-problem/#findComment-370934
one of the best things you can do is pull the board out of the case and test it outside the case making sure all connections are seated securely 24 pin power and 8 pin cpu connectors very important. place the board on top of a motherboard box Without the antistatic bag under it.
https://linustechtips.com/topic/29150-ga-z77x-up4-th-problem/#findComment-370954
Already tried that too..actually I already return the board for RMA but the technicians told me that they didn't found any problem with the board so they returned the same unit to me then after that I go to my friend's house to check the board outside the case. At first my friend manually adjust the BCLK to 100 and my PC boot normally again.So we thought the problem is already solved so I return to my home and install again all the parts but after 2 days the problem wen't back sometimes my PC won't boot I need to press the power button several times and sometimes I need to press first the reset button before the power button before it boots and now when I tried to change some settings in the BIOS there will be an error that I showed to you earlier
https://linustechtips.com/topic/29150-ga-z77x-up4-th-problem/#findComment-370968
you need to try different ram is my best guess then.
crucial had a bad batch of ram like 5-6 years ago ddr2 pc2-6400 bh3. i know because i went through a few of em. wouldnt surprise me if it happened again.
https://linustechtips.com/topic/29150-ga-z77x-up4-th-problem/#findComment-370982
I'll try to borrow some mems from my friend because I don't have a spare here.. And I will let you know if it's fixes the problem.
https://linustechtips.com/topic/29150-ga-z77x-up4-th-problem/#findComment-371002
https://linustechtips.com/topic/29150-ga-z77x-up4-th-problem/#findComment-371008
