Hi Guys
To start and fyi is hard for me to get a normal distilled water from where i am and i found out one brand which also kinda confuse me (the company sells mineral water called Spritzer if anyone knows it) have a product says process distilled on its label, as what i know we can't drink a plain water if it is distilled or it can, im not sure. So i am soon building up my first ever water cooled system so i recently found one of the local lab selling distilled water lab grade. So my question is can i use these instead? the seller did mention that these is use for labs only. Please help me on this if worst come to worst i just use a coolant.
Thanks in advance
Mobo:Rampage v Extreme **Processor: i7 5930X @ 4.7ghz**Ram:Corsair Vengence 2800 16GB**GPU: GTX Titan X**PSU: 1300W Cooler Master Silent Hybrid**Hard drive: 512gb Plexton Pro SSD**Samsung EVO 1TB SSD**Case: Enthoo Primo** All razers peripehal
WC : Alphacool NexXxoS UT60 480mm Radiator ***Phobya V2 480mm Radiator!!***EK R5E Full Mobo WB***Nickel EK-FC Titan X with Black Backplate from EK*** Bitspower com angle fittings*** Primochill Hardline Fittings**Bitspower Dual Pump top and 200mm Tube Z with MCP655 pwm***Primochill PETG** Mayhem Dye
Follow me in instagram #grimmmreaper88
https://linustechtips.com/topic/291339-distilled-water/
Distilled water is distilled water. You can use any distilled water for your loop and you won't die from drinking it.
60FPS Microwave
Intel Core i5-4670K | Galax GTX 970 EXOC | ASRock Z97E-ITX/ac | Team Elite 8GB 1600MHz | Gelid Black Edition | Samsung slowdown + WD Blue 1TB x2 | Cooler Master V550 | Corsair K65 + Logitech G100s | MasterCase Pro 3
https://linustechtips.com/topic/291339-distilled-water/#findComment-3956397
Hi Guys
Thanks in advance
Distilled water is just plain clean water, it has some electrons or something removed so that it won't be conductive. That's the only reason, they use it in labs and hospitals to make sure that the water is clean and won't make instruments rust. :)
https://linustechtips.com/topic/291339-distilled-water/#findComment-3956512
ahh ok.. thanks man.. you just saved me...
https://linustechtips.com/topic/291339-distilled-water/#findComment-3956518
explained.. nice.. ok i understand now.. Thanks.. cheers..
https://linustechtips.com/topic/291339-distilled-water/#findComment-3956520
Distilled water is H2O with vary few to no mineral content.
The mineral content in tap water or clorine if your in the citty is what hurts your blocks.
Distilled is like steam collected off off boiling water.
If you are going to use Distilled water in a loop ad a peace of silver wire.
You can buy them likliey at the same place as you did your water cooling bits.
Silver wire kills alge in you system. witch can grow in your loop.
https://linustechtips.com/topic/291339-distilled-water/#findComment-3956597
you are thinking of de-ionized water. Distilled water means it just had its impurities removed.
You can make distilled water at home really easily, just takes patience
I refuse to read threads whose author does not know how to remove the caps lock!
— Grumpy old man
https://linustechtips.com/topic/291339-distilled-water/#findComment-3962110
Thank you guys for the advise. Yeah is going to take patient to do it. I manage to get some lab distilled water. Thanks again... appreciate it. Im starting to watercooled my system and waiting for some parts from frozencpu. i post it when im done.. :)
https://linustechtips.com/topic/291339-distilled-water/#findComment-3972013
Lol die from drinking distilled water...right..
Current PC build: [CPU: Intel i7 8700k] [GPU: GTX 1070 Asus ROG Strix] [Ram: Corsair LPX 32GB 3000MHz] [Mobo: Asus Prime Z370-A] [SSD: Samsung 970 EVO 500GB primary + Samsung 860 Evo 1TB secondary] [PSU: EVGA SuperNova G2 750w 80plus] [Monitors: Dual Dell Ultrasharp U2718Qs, 4k IPS] [Case: Fractal Design R5]
https://linustechtips.com/topic/291339-distilled-water/#findComment-3972504
Actually, you could. Ever heard of water intoxication?
Case Phanteks Enthoo Evolv ITX | Motherboard Asus ROG Strix Z270i | CPU Intel i7-7700K | RAM Team Vulcan 16GB DDR4 | GPU Geforce GTX 1080 Ti | Storage Crucial MX300 1TB M.2 | PSU Corsair RM750x
https://linustechtips.com/topic/291339-distilled-water/#findComment-3973804
Yes I've heared of that but why would you do that?
60FPS Microwave
https://linustechtips.com/topic/291339-distilled-water/#findComment-3973814
Maybe someone's really thirsty and drinks a lot of water? Haha I don't know.
But anyway, you COULD die from drinking too much water.
https://linustechtips.com/topic/291339-distilled-water/#findComment-3973834
What Blocks are you ordering.
some blocks/Rads are not recomended fore use with distilled water.
just about all rads are advised to use distilled water just because that is the most common coolant
[-] i7 4790k @ 4.7ghz [-] Asus Maximus VII Formula [-] EVGA Gtx 980 Sc [-] Corsair H105 [-] Corsair Obsidian 750d [-]
https://pcpartpicker.com/user/TBNRunity/saved/#savedbuild_1797964
https://linustechtips.com/topic/291339-distilled-water/#findComment-3986127
Source, please?
[Main rig "ToXxXiC":]
CPU: Intel Core i7-4790K | MB: ASUS Maximus VII Formula | RAM: G.Skill TridentX 32GB 2400MHz (DDR-3) | GPU: EVGA GTX980 Hydro Copper | Storage: Samsung 850 Pro 256GB SSD + Samsung 850 EVO 1TB SSD (+NAS) | Sound: OnBoard | PSU: XFX Black Edition Pro 1050W 80+ Gold | Case: Cooler Master Cosmos II | Cooling: Full Custom Watercooling Loop (CPU+GPU+MB) | OS: Windows 7 Professional (64-Bit)
https://linustechtips.com/topic/291339-distilled-water/#findComment-3992030
