(Air Cooled) Forge: Carbon Fiber & Aluminum Corsair AIR 540
Gostop
putting it together, however I will be on vacation starting tomorrow and need to order a couple of more parts as well.
I also want sleeved cables but meh :<
  • 4 weeks later...
i7 4790k @ 4.8ghz (65c max temp @ 1.250 vcore)
R9 295x2 @ 1100/1400 (67c max temp)
Not bad eh?
Fellow 540 owner here, how well do the 360 & 240 mm radiators fit in there with fans?
CPU: i7 5820k @ 4.5Ghz | Mobo: MSI X99s SLI Plus | Ram: 16GB Crucial Balistix@2666Mhz | GPU: R9 270x (waiting for the 390x)
Case: Fractal Design S | PSU: Bitfenix Fury 750G | Storage: 240GB Samsung 840 evo + 2TB WD Red  http://linustechtips.com/main/topic/367346-neptunes-nox/
Four machines in a homemade ghetto rack | Intel i5 750 | AMD Athlon 64 4000+ | AMD Athlon 64 3500+ | AMD Athlon 64 3400+
with the r9 295x2 the fans had to be mounted on the outside of the case directly under the mesh. Which at first disabled the use of a fan filter, but I made one out of pantie hose lmao.
Other then that they fit perfect.
I was afraid that would be the answer, oh well, it still works and looks good. Can't wait to try to outdo the beauty you've made here.
  • 2 months later...
Update posted:
Switched to air cooling because of pump failures and other qc issues.
Switched from AMD (R9 295x2) to NVIDIA (2x GTX 980 TIs) because AMDs software is just too far behind, and I have grown impatient. I want AMD to succeed but I also want to have great reliable game experiences.
