Does it have to be free? - https://www.udacity.com/course/cs101
I done been through a whole lot. Trial, tribulations, but I know God - Kendrick Lamar
I question your mother's upbringing if you don't like me - Action Bronson
You apocalyptic dingleberry - James 'Captain Slow' May
Hello,
I have started to try and learn Python 2.7.2 but I am not sure of the best place to try and learn it. Anyone got any ideas?
Thanks in advance,
~ Harry
As I said yesterday, go try out DiveIntoPython. It is hands-down the easiest way to learn.
QUOTE ME OR I PROBABLY WON'T SEE YOUR RESPONSE
My Setup:
Desktop
CPU: Ryzen 9 3900X  CPU Cooler: Noctua NH-D15  Motherboard: Asus Prime X370-PRO  RAM: 32GB Corsair Vengeance LPX DDR4 @3200MHz  GPU: EVGA RTX 2080 FTW3 ULTRA (+50 core +400 memory)  Storage: 1050GB Crucial MX300, 1TB Crucial MX500  PSU: EVGA Supernova 750 P2  Chassis: NZXT Noctis 450 White/Blue OS: Windows 10 Professional  Displays: Asus MG279Q FreeSync OC, LG 27GL850-B
Main Laptop:
Laptop: Sager NP 8678-S  CPU: Intel Core i7 6820HK @ 2.7GHz  RAM: 32GB DDR4 @ 2133MHz  GPU: GTX 980m 8GB  Storage: 250GB Samsung 850 EVO M.2 + 1TB Samsung 850 Pro + 1TB 7200RPM HGST HDD  OS: Windows 10 Pro  Chassis: Clevo P670RG  Audio: HyperX Cloud II Gunmetal, Audio Technica ATH-M50s, JBL Creature II
Thinkpad T420:
CPU: i5 2520M  RAM: 8GB DDR3  Storage: 275GB Crucial MX30
Well, id rather not pay the $200 a month which that website charges  xD
pretty sure coursera is free - https://www.coursera.org/course/pythonlearn
This is like an actual course, though
also,
http://www.trypython.org
http://learnpythonthehardway.org
http://www.codecademy.com/en/tracks/python
Yup, I downloaded that yesterday :) I am also looks for a video playlist of some sort aswell :)
Nice! I basically just used the book, it worked like a dream.  But yeah, as @Flyguygamer says, http://www.lynda.com/wanshow/ is also a great option.
My Setup:
Desktop
Main Laptop:
Thinkpad T420:
I'm currently working my way through the course on codecademy, but I haven't really got too far through it, and can't really comment on much
Specs: CPU: AMD FX 6300 Motherboard: Gigabyte 970A DS3P RAM: HyperX Fury 16GB 1866MHz GPU: MSI R9 270 OC edition Case: Sharkoon VS3-S SSD: Samsung 840 EVO 120GB HDD: 1TB Caviar Blue PSU: Corsair CX500W
*If I say something that seems offensive, please don't take it seriously, it was most likely meant as a joke/sarcastically*
Firstly why are you starting with the older specification? Secondly if you don't already know about it you might like to try PyCharm, is an excellent IDE by JetBrains built on their ReSharper technology.
The single biggest problem in communication is the illusion that it has taken place.
I heard there wasn't much of a difference,  so I just got the 2.7.2 one. Is their a difference? Should I go to the 3. one?
It seems impossible until it's done.
Well unless there's a very good reason for not doing so one should always keep as current as possible in this industry. As for the differences see here and here.
This would depend on the reason that you are learning.
There is still a lot of companies that have 2.X code floating around and there are a few details that are different but if you get the concepts on 2.X then you can transfer to 3.X quite easy
Hello,
Thanks in advance,
~ Harry
I'm learning Python 2.7 currently and two great ways to learn it are codecademy.com and this book (downloadable as a free pdf) http://www.greenteapress.com/thinkpython/
CPU: AMD FX-6300 4GHz @ 1.3 volts | CPU Cooler: Cooler Master Hyper 212 EVO | RAM: 8GB DDR3
Motherboard: Gigabyte 970A-DS3P | GPU: EVGA GTX 960 SSC | SSD: 250GB Samsung 850 EVO
HDD: 1TB WD Caviar Green | Case: Fractal Design Core 2500 | OS: Windows 10 Home
If you're just picking up the syntax and basic rules, http://learnxinyminutes.com/ is really good. From there, come up with a simple project idea (a text-based calculator, perhaps), and apply the stuff you learned. Stackoverflow is an amazing resource, if you're having issues, and Google is a programmers best friend.
