So, my case is a Phanteks Enthoo Pro. Cpu is cooled with a Swiftech H240x, and this allows me with the option of comfortably adding an extra rad and the ability to cool a gpu as well without much trouble for the pump.
I have a Gigabyte GTX970 G1, and my question is if it should be water cooled, or if it is not needed. I might eventually sli in the future, but not immediately. I can fit a second radiator (a 240 or a 140) on the bottom of my case, or a 140 on the rear exhaust.
I understand that some waterblocks for this model of gpu are either out, or will be coming out soon, and would like to know how much would it effectively cost to add on the rad/waterblock to the existing loop. Also, if I add a second gpu in the future, will I need a third rad or will the two gpus be fine on a single rad? Again for the cost question, overall cost for mountings and so on if possible, and if it is worth it.
Still new, but learning
i7 4790K / GTX 970 G1 Gaming / Maximus VII Hero / Swiftech H240x / Corsair Vengeance Pro 16gb, 1600mhz, cl9 / 850 evo 250GB /
WD Blue 1TB / HX850 / Phanteks Enthoo Pro
https://linustechtips.com/topic/290640-question-on-gpu-cooling/
@drewjn remember to follow your topics so you get notified even if you aren't quoted or @ed
Is the gpu throttling due to temperature or is your overclock being limited by temp alone? If yes then watercool if no then watercooling won't really do much and at that point it's mainly a question of do you want to not should it be.
I am the one who goes bump in the night... usually making a sandwich.
Case: Phanteks Enthoo Primo White - Motherboard: ASUS X99 Deluxe - CPU: Intel i7 5820k - RAM: 4x4GB Corsair Vengeance 2666mhz ddr4 - GPU: Dual EVGA gtx 980 SSC - PSU: EVGA G2 Supernova 750w - Cooler: Custom PETG Loop on cpu and gpus - Storage: 500gb Samsung 850 evo ssd, 2x Seagate Barracuda 7200rpm 3tb hdd
https://linustechtips.com/topic/290640-question-on-gpu-cooling/#findComment-3946760
Fair enough, was wondering if it is preferable in sli. I've heard that the gigabyte cools decently enough. So it is more towards going all out if that is what you prefer. Even with sli, will the stock cools for decent gpus be fine?
https://linustechtips.com/topic/290640-question-on-gpu-cooling/#findComment-3947677
Well water cooling could help a lot in sli as the top card would be pulling hot air from the bottom card possibly making the top one over heat
[-] i7 4790k @ 4.7ghz [-] Asus Maximus VII Formula [-] EVGA Gtx 980 Sc [-] Corsair H105 [-] Corsair Obsidian 750d [-]
https://pcpartpicker.com/user/TBNRunity/saved/#savedbuild_1797964
https://linustechtips.com/topic/290640-question-on-gpu-cooling/#findComment-3947787
Only if the cards were basically touching which depends on the mobo my cards have over an inch gap between them in 2 way sli
https://linustechtips.com/topic/290640-question-on-gpu-cooling/#findComment-3950850
Water cooling will result in lower load and idle temps.
https://linustechtips.com/topic/290640-question-on-gpu-cooling/#findComment-3950884
Watercooling would yield much better temps but not necessarily fix your throttling issues. Custom parts like an EK-FC970 GTX WF3 - Acetal+Nickel block + an additional 240mm radiator would be around $200 in parts.
For much less money you could still get a great increase in performance by grabbing a good Asetek based 120mm AIO cooler like a Corsair H75 or Thermaltake Water 3.0 Pro and use a NZXT Kraken G10 bracket to spend around $120 and get really good performance (not as good as the full cover EK block option but still great compared to stock and much cheaper)
I am addicted to building gaming PCs but I don't have a great reason to stop...yet...
https://linustechtips.com/topic/290640-question-on-gpu-cooling/#findComment-3953584
Fair enough. Will likely think it over when I do upgrade to sli and if I see any major temperature issues for the gigabyte gtx 970 g1, when in sli.
Any suggestions on what software to use for monitoring temps and testing, or do they usually come included? The build I've made is the first real custom one as I used to just mainly buy prebuilt with lesser components.
https://linustechtips.com/topic/290640-question-on-gpu-cooling/#findComment-3955221
msi afterburner it will let you watch temps usage clock speeds, and change fan control and overclock if you want.
https://linustechtips.com/topic/290640-question-on-gpu-cooling/#findComment-3955697
