Posted January 14, 2015 Greetings! If you're reading this you've seen that i need help picking out some new memory for my system! I'm in need of all-black(or tasteful splash of color), DDR3 1600, 16GB (2x 8GB) RAM, budget is $200. I've gone through all the different options, but I can't seem to decide, so I'm gonna turn to you guys and I want you to help me pick out a kit. Link to comment https://linustechtips.com/topic/290586-need-help-choosing-memory/ Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted January 14, 2015 With that budget you can get almost any set of 1600mhz 2x8gb RAM Kit... I done been through a whole lot. Trial, tribulations, but I know God - Kendrick Lamar I question your mother's upbringing if you don't like me - Action Bronson You apocalyptic dingleberry - James 'Captain Slow' May Link to comment https://linustechtips.com/topic/290586-need-help-choosing-memory/#findComment-3945752 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted January 14, 2015 Author With that budget you can get almost any set of 1600mhz 2x8gb RAM Kit... My usage of Autodesk products and high memory usage games limits my use of 8GB kits. Link to comment https://linustechtips.com/topic/290586-need-help-choosing-memory/#findComment-3945763 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted January 14, 2015 Solution Here are some options http://www.newegg.com/Product/Product.aspx?Item=N82E16820104461&cm_re=hyperx_fury-_-20-104-461-_-Product http://www.newegg.com/Product/Product.aspx?Item=N82E16820233246&cm_re=corsair_vengance-_-20-233-246-_-Product http://www.newegg.com/Product/Product.aspx?Item=N82E16820104363&cm_re=hyperx_ddr3_beast-_-20-104-363-_-Product Link to comment https://linustechtips.com/topic/290586-need-help-choosing-memory/#findComment-3945767 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted January 14, 2015 Author I'm digging the Fury kit, 1866MHz, nice bonus! Thanks dude! Link to comment https://linustechtips.com/topic/290586-need-help-choosing-memory/#findComment-3945794 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted January 14, 2015 My usage of Autodesk products and high memory usage games limits my use of 8GB kits. ..Ok? I dont understand what you're getting at. I'm just saying that with a budget of $200, you can get almost any RAM kit with your requirements (i.e. 1600mhz, 2x8gb, all-black) Some ideas so black ram. I done been through a whole lot. Trial, tribulations, but I know God - Kendrick Lamar I question your mother's upbringing if you don't like me - Action Bronson You apocalyptic dingleberry - James 'Captain Slow' May Link to comment https://linustechtips.com/topic/290586-need-help-choosing-memory/#findComment-3945802 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted January 14, 2015 Author ..Ok? I dont understand what you're getting at. I'm just saying that with a budget of $200, you can get almost any RAM kit with your requirements (i.e. 1600mhz, 2x8gb, all-black. Yeah, sorry about that, I read your post wrong. Link to comment https://linustechtips.com/topic/290586-need-help-choosing-memory/#findComment-3945818 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted January 14, 2015 Yeah, sorry about that, I read your post wrong. It's all good Just choose whichever kit you think looks the best. With you budget, I would get some Dominator Platinums Or you could get some fast RAM I done been through a whole lot. Trial, tribulations, but I know God - Kendrick Lamar I question your mother's upbringing if you don't like me - Action Bronson You apocalyptic dingleberry - James 'Captain Slow' May Link to comment https://linustechtips.com/topic/290586-need-help-choosing-memory/#findComment-3945833 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted January 14, 2015 http://www.newegg.com/Product/Product.aspx?Item=N82E16820313325&cm_re=ddr3_2400_2x8-_-20-313-325-_-Product Mainboard Asrock Z170 OCF CPU 6700k RAM Tridentz 3600 HDD Intel 730 240gb GPU GTX 780ti sc acx PSU Silverstone Strider 1200W Case Antec 900 Laptop Lenovo Thinkpad T520 build log- http://linustechtips.com/main/topic/35809-antec-900-the-re-birth-of-a-legend/ Check out the Tech Center https://www.youtube.com/user/prokon24/videos LTT's Unicore King Link to comment https://linustechtips.com/topic/290586-need-help-choosing-memory/#findComment-3945834 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted January 14, 2015 Here are some options http://www.newegg.com/Product/Product.aspx?Item=N82E16820104461&cm_re=hyperx_fury-_-20-104-461-_-Product http://www.newegg.com/Product/Product.aspx?Item=N82E16820233246&cm_re=corsair_vengance-_-20-233-246-_-Product http://www.newegg.com/Product/Product.aspx?Item=N82E16820104363&cm_re=hyperx_ddr3_beast-_-20-104-363-_-Product 1866 CL10. Can get better for the price. 1600 CL10. Really? 1600 CL9. Better but again you can get better ram for that price or slightly more. http://www.newegg.com/Product/Product.aspx?Item=N82E16820313325&cm_re=ddr3_2400_2x8-_-20-313-325-_-Product I think the price different is worth going with G. Skill. Trident X 2400 CL10 @ $159 http://www.newegg.com/Product/Product.aspx?Item=N82E16820231589 Also, removable heatsinks to allow for large air coolers and more options down the road. Best ram I can find for at 200 or close to it is. 2666 CL11 http://www.newegg.com/Product/Product.aspx?Item=N82E16820231601 Link to comment https://linustechtips.com/topic/290586-need-help-choosing-memory/#findComment-3945909 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted January 14, 2015 I think the price different is worth going with G. Skill. http://www.newegg.com/Product/Product.aspx?Item=N82E16820231589 Also, removable heatsinks to allow for large air coolers and more options down the road. i agree 100% the gskill is a better kit. gskill tridents offer the best bang for the buck. was gonna suggest it since the op did say "splash of color" but i went with the blacked out cheaper selection instead. Mainboard Asrock Z170 OCF CPU 6700k RAM Tridentz 3600 HDD Intel 730 240gb GPU GTX 780ti sc acx PSU Silverstone Strider 1200W Case Antec 900 Laptop Lenovo Thinkpad T520 build log- http://linustechtips.com/main/topic/35809-antec-900-the-re-birth-of-a-legend/ Check out the Tech Center https://www.youtube.com/user/prokon24/videos LTT's Unicore King Link to comment https://linustechtips.com/topic/290586-need-help-choosing-memory/#findComment-3945923 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted January 14, 2015 i agree 100% the gskill is a better kit. gskill tridents offer the best bang for the buck. was gonna suggest it since the op did say "splash of color" but i went with the blacked out cheaper selection instead. Yup, But if the OP were to remove the red heatsinks then the top of the ram is solid black, black PCB, etc. It does have the red sticker on the side. And Corsair Dom. Plats are still overpriced. Link to comment https://linustechtips.com/topic/290586-need-help-choosing-memory/#findComment-3945934 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
