Hey guys!
I have a stereo amplifier connected to two speakers, as one does.
The stereo is rated for 2x 55W output power, and both speakers say "Maximum input power 100W"
What exactly does this mean? Is it fine to crank is all the way? And is there a time limit or something, since it says maximum, not mean?
Thanks!
Intel Core i7-3770k @4.4GHz. 1.170V - Noctua NH-D14 - 8GB (2x4) G.Skill RipjawsX @1866 MHz. CL8 - Gigabyte GA-Z77X-D3H - Samsung 840 250GB - XFX HD7970 DD GHz. @1125MHz - CM 690 II - Seagate Barracuda 2TB + WD RED 3TB - Corsair RM750X
 FiiO E10 - Sennheiser HD 598 - Edifier R1600T - Sony MHC-EX50 - Razer Blackwidow Ulitmate 2013 - Razer Deathadder 2013 - LG IPS237L - Dell P2314H - Philips 237EQPH - LG 47LB561V
 LG G2 - HP Spectre X360 - Audio Technica ATH-M50X - Sennheiser IE 60
https://linustechtips.com/topic/290382-speaker-input-rating/
It's fine since 25w will most likely be way louder than you need.
I know, but I just kind of want to know if I need to worry if max volume is too high.
Say, if I need to monitor what guests do, or if it really doesn't matter for the speakers.
https://linustechtips.com/topic/290382-speaker-input-rating/#findComment-3943971
Nah, just listen to the music and:
It's fine, turn it down when it audibly distorts.
Grammar and spelling is not indicative of intelligence/knowledge.  Not having the same opinion does not always mean lack of understanding.
https://linustechtips.com/topic/290382-speaker-input-rating/#findComment-3948205
the wattage is only part of the info you need. impedence (in ohm) is more important. for exemple: if you send a 50W @ 4ohm signal to a speaker than can handle 100w @ 4ohm it will be ok. But if you send a 50w @ 4ohm signal to a speaker tha can handle 100w @ 8ohm, you amplifier is likely to overheat and redure its performance and life time. The opposite is also true, if you send a 50w @ 8ohm to a speaker designed to receive a 50w @ 4ohm, you speaker is likely to overheat(creating distortion) and will eventually burn from the inside.
ohm is the amount of electricity allowed at a given moment
watt is the amout of power allowed at a given moment
https://linustechtips.com/topic/290382-speaker-input-rating/#findComment-3952876
no
EDIT: not too sure what you are trying to say, but you don't send watts and over heating will not occur in speakers specifically due to resistance.
https://linustechtips.com/topic/290382-speaker-input-rating/#findComment-3953229
You can't 'sent' watts, you apply voltage. Since ohm works inverse (P=U^2/2R), the less ohms a speaker has the more watts (P=U*I) you get from the same voltage.
50W at 8 ohm would be 25W in 4 ohm. You can't choose impedance, it's determined by the speaker you use.
Not to be rude, but literally 90% of your post is incorrect.
no
Actually, yes it does :) Assuming the same voltage, lower resistance would result in higher current flow.
That is part of the reason that you don't see a lot of 2 ohm speakers in the PA world, this would cause huge power compression issues or even a melting VC.
https://linustechtips.com/topic/290382-speaker-input-rating/#findComment-3953334
Keeping in context (and simple), I used the word "specifically", because it's both rare to find 2 ohm speakers and in order to damage a speaker you need to drive it further than distortion,  Keeping the volume low (thus voltage low) on a 4 ohm speaker should not result in it over heating.  :)
https://linustechtips.com/topic/290382-speaker-input-rating/#findComment-3954035
Watts don't really mean shit. What matters is the sensitivty of the speakers and we measuer this in Ohms. The more sensitive and quality the speakers the less Watts they take to drive. A Cerwin Vwga speaker rated at 100watts max power handling would sound much louder and clear when driven @ 100watts comparied to a crap speaker that would just literally fall apart.
https://linustechtips.com/topic/290382-speaker-input-rating/#findComment-3954400
Sensitivity is measured in dB/w/m or dB/2.83v/m. The last one takes impedance into play with 4 ohm being +3dB over 8 ohm (2.83v is 2w in 4 ohm)
https://linustechtips.com/topic/290382-speaker-input-rating/#findComment-3955322
Sensitivity in ohms? Woot??
Also, drive a speaker with 100W max power with a continuous 100W from an amp, it will distort like crazy for a few seconds, and die. Max power handling is reserved for spikes in loudness, not intended for continuous operations.
https://linustechtips.com/topic/290382-speaker-input-rating/#findComment-3955410
*facts
@creatip123 max power handling is useless, even RMS is often. Thermal music load is at least 10-12db under peak and the sub will bottom out way early.
@ Facts ... get a quality set ! Fuck me right ... buy quality ... but fuck that right LOL !
https://linustechtips.com/topic/290382-speaker-input-rating/#findComment-3955629
Sigh. A quality set of speakers are sensitive.
Why the 'sigh' man, I'm not an ignorant spammer trying to attack you. Just explaining so you can learn from it. You can't get around physics (hoffman's iron law). If you want a small speaker with good bass it's going to be inefficient. A good designer can maximize the results, but there is a limit. Most worldclass speakers are 'only' 90dbwm or even lower because they choose bass extension over sensitivity.
https://linustechtips.com/topic/290382-speaker-input-rating/#findComment-3955725
That's why all the good speakers are extreamly sensitive.
https://linustechtips.com/topic/290382-speaker-input-rating/#findComment-3955771
Absolutely not, not even a little bit.
So driver manufacturers put most of their R & D efforts into low sensitivity drivers that can play deep in a small cabinet
http://www.salksound.com/wp/?p=56
https://linustechtips.com/topic/290382-speaker-input-rating/#findComment-3955794
LOL ok dude I guess all high end speaker and mid range cant pick up shit from thy ground LOL.
that doesn't even make sense.
https://linustechtips.com/topic/290382-speaker-input-rating/#findComment-3955816
Because they're small and lack bass? I think you misinterpreted my point. Since power is so cheap nowadays even the highest quality speakers choose bass extension over sensitivity for a given size. But I think we can both indeed agree that reasonable quality speakers are often more sensitive/efficient than your average 30 bucks wallmart speaker.
https://linustechtips.com/topic/290382-speaker-input-rating/#findComment-3955817
A high quality Bowers and Wilkens 20Watt can put out more Quality sound including Bass, Mids and Treble etc than a Logitec POS 500Watt watt LOL !
https://linustechtips.com/topic/290382-speaker-input-rating/#findComment-3955843
