Help a noob out please!
Go to solution Solved by Jack.EXE,
http://www.msimobile.com/level3_productpage.aspx?cid=6&id=391
fits your budget, and you have 200 to spare on a good mouse & headset.
Hi guys, I have a nice little budget of 1500 buck to use. I really want a gaming .... laptop; mainly for portability reasons. I have never purchased one before and dealing with mobile hardware, I don't know what i'll really be getting for my money. Help a guy out please!
I'm trying to be able to play the latest games on high settings 1080p at most(Definetily something like dayz and wareframe). Thanks for any suggestions. ~ExKingb12
https://linustechtips.com/topic/29016-help-a-noob-out-please/
http://www.ibuypower.com/Store/Battalion_101_P151SM1_Gaming_Laptop
change the HDD to a 1TB drive and add an SSD,also make sure to tick the boxes for the free games.
Linus Sebastian said:
The stand is indeed made of metal but I wouldn't drive my car over a bridge made of it.
https://youtu.be/X5YXWqhL9ik?t=552
https://linustechtips.com/topic/29016-help-a-noob-out-please/#findComment-368931
If you need the Laptop for LANs and so on, I'd suggest a mini ITX build, as it will be much more powerful.
If you carry your machine around 24/7 have a look at the MSI Gaming-Series laptops. And stay FAR AWAY from the ASUS ROG G7x series Laptops. They are not worth the plastic they are made of.
Frost upon these cigarettes.... lipstick on the window pane...
https://linustechtips.com/topic/29016-help-a-noob-out-please/#findComment-368950
Wow, that's actually a good deal. Not fond of those apu's. Would they really be able to handle what I am asking?
https://linustechtips.com/topic/29016-help-a-noob-out-please/#findComment-368989
