Enthoo Pro GPU Cooling question
Stock fans are goodI am getting the enthoo PRO with NZXT Kraken X61 106.1 CFM Liquid CPU Cooler and the using the two included fans the front 200mm. and back 140mm.
I will have a 4790k and be using 2x MSI GTX 970s and I plan to over clock the CPU and GPU.
I was thinking of getting one more fan to help with GPU cooling. I noticed Enthoo Pro can have fans mounted in the HDD Cages in a Review I was watching. I am unsure of the size tho. the Review didnt say or atleast I can find where they said it. it was a long review. And I am reading from the site correctly it says 2x 120mm HDD. But do I have to use 120mm? Cause I use 1 140mm instead? and if I put a fan in the position will it help with GPU Cooling and cooling period. or is it not even really neccessary.
I know I should probably upgrade the stock fans, But I am already slightly over budget.
Remove the hard drive cages you don't need, that will improve cooling.
