sound cards have nothing to do with fps games...
https://linustechtips.com/topic/290007-sound-card/#findComment-3937581
what headphones you recommend ?  :mellow:
I'd recommend something that's quite comfortable if you're using it for long periods of time.
I have the ATH m50, and I must say that it gets uncomfortable over hours of use ...
I hear Shure has good and comfortable headphones... also, how much are you willing to spend?
https://linustechtips.com/topic/290007-sound-card/#findComment-3943501
Headsets with USB ?  example Logitech G430 7.1 I maybe buy this headsets but question cs:go have only 5.1sound  and this headsets have 7.1 or maybe someone know good headsets usb for fps games ?
Gaming headsets are just a gimick and another way of saying cheap, crappy low quality, unclassy sounding.
https://linustechtips.com/topic/290007-sound-card/#findComment-3943556
