Hello.
Please can you help me to choose some good solid memory?
- DDR3
- 2x8 GB (16GB)
- CL9
- 1866 MHz
- Quality brand
- Red color and good looking
- XMP
Thank you very much for help.  :)
Here's a great set of ram: http://www.newegg.com/Product/Product.aspx?Item=N82E16820231416&cm_re=8gb_sniper-_-20-231-416-_-Product
My arsenal: i7-9700k Gaming Rig, an iPhone, and Stupidity.
https://linustechtips.com/topic/289638-ram-choosing-help/#findComment-3932523
Europe, Slovakia.
Kingston Fury Red series is quite good. Gave you the UK link as it's in the EU.
http://uk.pcpartpicker.com/part/kingston-memory-hx318c10frk216
There's also the Corsair Vengeance Pro series if you don't mind spending more money. They'll perform the same, but they look better IMO.
Between CAS and speed, 1600MHz CL10 will perform the same (as near as makes no difference) as CL8/9 1866MHz, so don't worry about the specs too much.
https://linustechtips.com/topic/289638-ram-choosing-help/#findComment-3932644
