So about 2 months ago i noticed some weird lags and stutters in TF2. I thought nothing of it for the first month as it only happened very occasionally and for a short time (1 second or less) but now it is much worse and sometimes causes the game to crash.
What i have done so far:
1) Verified game cache:
                         This led nowhere because every time i checked (after playing and then crashing) 1 or 2 files were missing and had to be reacquired. Note: it seems this is the problem but i don't know which files are missing :S
2) Re-installing TF2 (deleting local content first):
                         Didn't work, had same problem as stated above.
3) Making my CFG less cluttered:
                         Didn't help either.
I will make a short clip with my phone soon. If you need my cfg (to inspect the problem) just let me know and i'll upload it.
I would really appreciate a fix for this problem as i play tf2 as my MAIN hobby and it would suck "BIG TIME" if i couldn't play it anymore.
UPDATE:
4) Run chkdsk and memcheck
5) put dxlvevl 81 in launch options
6) Re-installing drivers
7) Re-installing direct x (windows wise)
Samung Tab S 8.4
https://linustechtips.com/topic/289587-tf2-problem/
Run memory diagnostics and checkdisk.
On it (chkdsk).
I have an issue though, i can not get any memtest to run.
And reinstall DirectX versions in the game too, they can occasionally cause problems.
How do i do that though.
Samung Tab S 8.4
https://linustechtips.com/topic/289587-tf2-problem/#findComment-3931872
Are you running game in windowed mode? Because that causes it to stutter for me. So my options are stutter in windowed and crash everytime I Alt-Tab with full screen.
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
https://linustechtips.com/topic/289587-tf2-problem/#findComment-3938214
Nope. Tried windowed and fullscreen (and windowed borderless).
Samung Tab S 8.4
https://linustechtips.com/topic/289587-tf2-problem/#findComment-3938667
