Almost no difference?
With low end gpu's it's pretty much the same, with high end gpu's fx can't keep up.
https://linustechtips.com/topic/289163-almost-no-difference/#findComment-3925873
This is how i read your post.
Almost EVERY test says that i5/i7 are better, BUT maybe this random one could disprove that...
https://linustechtips.com/topic/289163-almost-no-difference/#findComment-3925880
FX CPUs aren't that far removed from Pentium 4s. So I'm always surprised to see the odd benchmark that shows they can actually perform better than some cpus in the i5/i7 range (they can beat some of the earlier i5s, but not the newest ones). AMD really screwed up their FX line.
           .;ldkO0000Okdl;.                michael@SUSE-BlackBox
        .;d00xl:^''''''^:ok00d;.            OS: openSUSE 20260405
      .d00l'                'o00d.          Kernel: x86_64 Linux 6.19.11-1-default
    .d0K^'  Okxoc;:,.          ^O0d.        Uptime: 2d 21h 52m
   .OVVAK0kOKKKKKKKKKKOxo:,      lKO.       Packages: 6556
  ,0VVAKKKKKKKKKKKKK0P^,,,^dx:    ;00,      Shell: bash 5.3.9
 .OVVAKKKKKKKKKKKKKk'.oOPPb.'0k.   cKO.     Resolution: 3840x1080
 :KVAKKKKKKKKKKKKKK: kKx..dd lKd   'OK:     DE: KDE
 lKlKKKKKKKKKOx0KKKd ^0KKKO' kKKc   lKl     WM: KWin
 lKlKKKKKKKKKK;.;oOKx,..^..;kKKK0.  lKl     GTK Theme: Breeze-Dark [GTK2], Breeze [GTK3]
 :KAlKKKKKKKKK0o;...^cdxxOK0O/^^'  .0K:     Icon Theme: breeze-dark
  kKAVKKKKKKKKKKKK0x;,,......,;od  lKP      Disk: 13T / 22T (60%)
  '0KAVKKKKKKKKKKKKKKKKKK00KKOo^  c00'      CPU: AMD Ryzen 7 5800X3D 8-Core @ 16x 4.55295GHz
   'kKAVOxddxkOO00000Okxoc;''   .dKV'       GPU: AMD Radeon RX 6700 XT (radeonsi, navi22, ACO, DRM 3.64, 6.19.11-1-default)
     l0Ko.                    .c00l'        RAM: 13127MiB / 48094MiB
      'l0Kk:.              .;xK0l'
         'lkK0xc;:,,,,:;odO0kl'
             '^:ldxkkkkxdl:^'
https://linustechtips.com/topic/289163-almost-no-difference/#findComment-3925915
I'm seeing GTX660s, 660 isn't enough to show the difference.
I was unable to get my Core 2 Duo E8500 @  4GHz to bottleneck a GTX 650 ti 2GB (slightly cut down GTX 660, and with a 250MHz OC on mine), so there is no way you can get a true indicator of an FX CPUs performance with them.
      'l0Kk:.              .;xK0l'
             '^:ldxkkkkxdl:^'
https://linustechtips.com/topic/289163-almost-no-difference/#findComment-3925935
I alrady said i wass impressed by the Numbers so that i forgot to look at what graphics card they used
https://linustechtips.com/topic/289163-almost-no-difference/#findComment-3925967
I alrady said i wass impressed by the Numbers so that i fergot to look at what graphics card they used
I know. I think tests like that are done by people unable to afford decent hardware, either that or AMD fanboys trying to put their CPUs in a good light.
      'l0Kk:.              .;xK0l'
             '^:ldxkkkkxdl:^'
https://linustechtips.com/topic/289163-almost-no-difference/#findComment-3925995
You need a high end gpu to tell the difference.
With a mid-low end gpu you can say that an i3 is as good as an i5 4670k!
And make a big bold statement and post in the forums.
Who buys an i5 is a moron there is no difference
/s
https://linustechtips.com/topic/289163-almost-no-difference/#findComment-3926139
/s
I don't really trust Austin's reviews after watching a few of them, and especially when he uses low end hardware for his benchmarks (that video clearly shows the graphics card at its limits). Now if it was a real graphics card like a 690, 780/ti and a 970 then things would be different. (AMD R9 290X as well I suppose).
      'l0Kk:.              .;xK0l'
             '^:ldxkkkkxdl:^'
https://linustechtips.com/topic/289163-almost-no-difference/#findComment-3926167
Lol wut , he used a gtx 780 at the end.
http://www.anandtech.com/show/8427/amd-fx-8370e-cpu-review-vishera-95w
If people think the cpus are the same you should check this review from anadatech where they use multi gpus and high end gpus to test the cpu.
https://linustechtips.com/topic/289163-almost-no-difference/#findComment-3926177
