Hi guys. I was wondering can I get setup like this: When I enter into CoD2 that my monitor brightness goes to 120% (it can be done in CCC) and when I exit it returns to 100% - normal value. In CCC you can set gaming profiles for AA, tessalation and other stuff, is there any option to change brightness too? I hope you understand me and sorry for bad english :)
Hoe Hoe Hoe and a bottle of RAM © Gankplank
https://linustechtips.com/topic/288871-need-help/
You're saying you can do that in CCC, so why not do it?
Or are you using Nvidia instead of AMD?
https://linustechtips.com/topic/288871-need-help/#findComment-3921822
Is there option so it automaticly switches from 100% brightness to 125% when I enter game and it returns to 100% when I exit. It can be done manualy in CCC but I want it to be auto. I am using AMD GPU and in CCC for game profiles you can just change AA, tessalation, texture filltering, frame rate control but there is no brightness to change or set. http://i.imgur.com/BR9YPv9.jpg
https://linustechtips.com/topic/288871-need-help/#findComment-3921853
You can change the brightness level separately in COD 2 IIRC
you can't in windows 8.1, it doesn't even reckognise it as game. You change brightness/gamma values ingame or in config, but it doesn't change anything. That is why I use the CCC brightness option, but it gets boring to raise it and lower every time I enter or quit the game. And yes the game is set to compactibility mode - windows xp and I run it as administrator.
https://linustechtips.com/topic/288871-need-help/#findComment-3921895
