I'll be doing a full scale water loop for my next build. Progressing from AIO type unit.
From what I have read that distilled water is the water of choice.
But as I work in maintenance in a Hospital & have access to Ultra pure water that has gone
through a plant that filters water to be used for Renal Dialysis.
1. Which takes all the particulates out at 0.005 micron.
2. Water softener which takes out calcium magnesium, and certain other metals.
3. Dual stage carbon filters which removes 99% of the chlorine.
4. Through a UV filter that kills all the bacteria left in the water.
Then you are left with Ultra Pure Water.
I was thinking of using this water for my loop.
I would still be using a silver killcoil, even though the UV filter would get rid of the bacteria.
Any thought on this would be appreciated & welcomed
Cheers
Pic of the water plant
https://linustechtips.com/topic/288793-water-type-to-use/
is it nonconductive after all those things? because deionized and distilled are both pretty much nonconductive.
https://linustechtips.com/topic/288793-water-type-to-use/#findComment-3920939
Well lets say that water is to spill it won't short out the parts but it will soon pickup minerals in the motherboard and be conductive if you are to "water" cool use mineral oil.
mineral oil is not something to be used in loops... Mineral oil is not nearly as good as distilled water. I believe water transfers heat almost twice as good as mineral oil.
[-] i7 4790k @ 4.7ghz [-] Asus Maximus VII Formula [-] EVGA Gtx 980 Sc [-] Corsair H105 [-] Corsair Obsidian 750d [-]
https://pcpartpicker.com/user/TBNRunity/saved/#savedbuild_1797964
https://linustechtips.com/topic/288793-water-type-to-use/#findComment-3926427
found this in the Water Cooling 101 - A good place for newbies to start thread
Thermal Conductivity of Common Cooling Mediums (@~20°C; W/mK)
Higher values are better
Water...............................................0.610
Mineral Oil........................................0.162
Alcohol(Ethyl, Isopropyl, Buytl)...........0.161-0.200
Ethylene Glycol..................................0.258
Air...................................................0.0257
Specific Heat of Common Cooling Mediums (@~20°C;kJ/kg.K)
Water...............................................4.19
Air...................................................1.00
Mineral Oil........................................1.67
Copper.............................................0.093
Ethylene glycol..................................2.36
https://linustechtips.com/topic/288793-water-type-to-use/#findComment-3927056
Really? I thought all custom water loops used mineral oil.
Then they would be oil loops wouldn't they?
I am the one who goes bump in the night... usually making a sandwich.
Case: Phanteks Enthoo Primo White - Motherboard: ASUS X99 Deluxe - CPU: Intel i7 5820k - RAM: 4x4GB Corsair Vengeance 2666mhz ddr4 - GPU: Dual EVGA gtx 980 SSC - PSU: EVGA G2 Supernova 750w - Cooler: Custom PETG Loop on cpu and gpus - Storage: 500gb Samsung 850 evo ssd, 2x Seagate Barracuda 7200rpm 3tb hdd
https://linustechtips.com/topic/288793-water-type-to-use/#findComment-3928919
Cheers
As long as you flush and wash your water blocks, rads and res i think if you can get a few litres of that stuff it would be amazing. ++ Try to wash the components out with the distilled water if possible.
Of course using the appropriate things in the loop like a kill coil, as even with the UV filter i think bacteria will grow back at a certain rate if it is exposed to the air, same thing happens with the minerals.
No generally in AIO and a lot of water loops are a mixture of glycol and other additives to the water to reduce algae and mineral build up.
Edited by kachel94
Asus Z77 Sabertooth, Intel Core i5 3570k 4.2 GHz, EVGA GTX 780, Corsair Vengeance 16Gb ,
Samsung EVO 250&500Gb, Western Digital Black 2TB,  Corsair RM 750
Custom Water Loop
CPU Block Koolance 380iGPU Block EKWB Clean CSQPump Laing DDC w/ EKWB X-RES 100Radiatiors NexXxoS Monsta 240 & Swiftech 240x35Tubing PrimoChill Primoflex Advanced LRT Elegant White 3/8" ID 5/8" ODFittings White Monsoon Free Centre Compression Fittings 3/8" ID 5/8" ODFans6x Noctua NF-F12 w/Noctua LNA Adaptors
https://linustechtips.com/topic/288793-water-type-to-use/#findComment-3928990
Pure water is highly polar though, so even if it does not contain any metal ions it will pick them up on the way and hence become conductive.
Lorem ipsum dolor sit amet, consectetur adipiscing elit. Quisque euismod suscipit est, non placerat turpis vestibulum sed. Phasellus et faucibus odio. Donec a nisi at purus porttitor ullamcorper auctor a nibh. Integer id neque a nisi laoreet ultrices id ac augue. Nulla facilisi. Nullam purus elit, dictum quis euismod vitae, mollis non dui. Morbi vehicula neque eu mattis bibendum. Curabitur sed odio tortor. Sed euismod mi in diam volutpat, vitae convallis ipsum mattis. Praesent eleifend faucibus pulvinar. Interdum et malesuada fames ac ante ipsum primis in faucibus. Vestibulum velit nunc, fermentum a libero a, venenatis tempus lectus.
https://linustechtips.com/topic/288793-water-type-to-use/#findComment-3929085
If you're using pure water use a silver coil or better yet 99.9% pure silver, of course coolant isn't cheap...
don't use dye either, stay away from red(stains everything)
I'm Batman!
Steam: Rukiri89 | uPlay: Rukiri89 | Origin: XxRukiriXx | Xbox LIVE: XxRUKIRIxX89 | PSN: Ericks1989 | Nintendo Network ID: Rukiri
Project Xenos: Motherboard: MSI Z170a M9 ACK | CPU: i7 6700k | Ram: G.Skil TridentZ 16GB 3000mhz | PSU: EVGA SuperNova 850w G2 | Case: Caselabs SMA8 | Cooling: Custom Loop | Still in progress
https://linustechtips.com/topic/288793-water-type-to-use/#findComment-3929203
You made my day, sir. xD
Current PC build: [CPU: Intel i7 8700k] [GPU: GTX 1070 Asus ROG Strix] [Ram: Corsair LPX 32GB 3000MHz] [Mobo: Asus Prime Z370-A] [SSD: Samsung 970 EVO 500GB primary + Samsung 860 Evo 1TB secondary] [PSU: EVGA SuperNova G2 750w 80plus] [Monitors: Dual Dell Ultrasharp U2718Qs, 4k IPS] [Case: Fractal Design R5]
https://linustechtips.com/topic/288793-water-type-to-use/#findComment-3929421
Oh man. That's cool. I work on a trach-dialysis patient floor. Did NOT know that the water used was treated like that. Honestly, it'll be pretty cool to know how well the water holds up but unless there's sunlight or light in your PC it should be hard for algae growth. I game in the dark anyways. Bacteria growth.. I'll worry more about plasticizer or corrosion first.
https://linustechtips.com/topic/288793-water-type-to-use/#findComment-3929706
Cheers for the info guys.
I don't need to worry about getting a cpl of litres.
I can get pretty much as much as I like
https://linustechtips.com/topic/288793-water-type-to-use/#findComment-3947573
I don't think that matters. Any liquid will be come conducive. Water might be more due to hydrogen-bonding, but as long as the water stays in the loop, the conductivity does not matter
https://linustechtips.com/topic/288793-water-type-to-use/#findComment-3947583
