Hi, i am currently planning to upgrade my pc graphic card and psu , but i am not sure if the rest of the spec are good or bad. I am mainly using it for gaming and some 3D modeling
Current Rig:
Intel Core i7 3770 3.4 Ghz
8GB DDR3 - 1600
1TB hardrive
Window 8
basically : http://h20564.www2.hp.com/hpsc/doc/public/display?docId=emr_na-c03639145-7 this is my computer,
i am planning to get Seasonic G-750w psu and a Radeon R9 290x Graphic card, any advice anyone? should i change my  motherboard anything?
Apologize for the messy information.  :)  :)
https://linustechtips.com/topic/288753-planning-advice-needed/
You dont need a 750W psu, 500-600 would be fine as well, this one is also from Seasonic: http://pcpartpicker.com/part/seasonic-power-supply-ssr550rm
The motherboard will work fine for a single card configuration, and the rest of you system is looking ready for a new gpu as well. ;)
Personal Build Project "Rained-On"
helped building up the CPU Overclocking Database and GPU Overclocking Database, check them out ;)
#KilledMyWife #MakeBombs #LinusIsNotFunny || Please, dont use non-default grey font colors. Think about the night-theme users! ;)
https://linustechtips.com/topic/288753-planning-advice-needed/#findComment-3920392
Thanks for the advice, i will switch to seasonic G-650  :D
https://linustechtips.com/topic/288753-planning-advice-needed/#findComment-3920421
sounds like a good idea to me. also one upgrade for usability I would look into is a SSD for boot. it's going to make your computer Feel fast but won't technically improve performance. the difference is enough that I don't have a single computer using a mechanical hard drive to boot. even my media center/fileserver that never shuts down has a SSD for boot.
https://linustechtips.com/topic/288753-planning-advice-needed/#findComment-3920436
yeah but in reality that CPU isn't bad at all. I have the unlocked version and even at stock clocks it doesn't feel held back.
Wait until you have to render 3d vray animations
https://linustechtips.com/topic/288753-planning-advice-needed/#findComment-3920443
You got me on that one. Only rendering I do is in adobe premiere pro CC.
With my 3820 it took 3 days to render a simple 40 second animation
https://linustechtips.com/topic/288753-planning-advice-needed/#findComment-3920453
You should be fine, although a cpu upgrade is recommended
CPU: i5-4690k GPU: 280x Toxic PSU: Coolermaster V750 Motherboard: Z97X-SOC RAM: Ripjaws 1x8 1600mhz Case: Corsair 750D HDD: WD Blue 1TB
How to Build A PC|Windows 10 Review Follow the CoC and don't be a scrub~soaringchicken
https://linustechtips.com/topic/288753-planning-advice-needed/#findComment-3920504
What do you mean?
So a 650 or 750 would be better?
I mean you might want to bump up the CPU due to the fact that you use 3d rendering/modeling software
https://linustechtips.com/topic/288753-planning-advice-needed/#findComment-3920623
