Could someone please clarify for me something about switches because I am looking for a cheap gigabit switch and I saw a switch say it has two gigabit ports and the rest 100 bit. I don't know what exact switch it was but I suddenly got confused. I thought all gigabit switches every port is 1000 bits per/s (or something like that). Could someone clarify please? Thanks.
Project Restomod (In progress)
https://linustechtips.com/topic/28861-gigabit-switches/
Gigabit=128 megabytes. Can you give me the link to this switch?
https://linustechtips.com/topic/28861-gigabit-switches/#findComment-366884
How many ports do you need?
I've got a Longshine Switch 8x GE GS7108-D and a Linksys SE2800 both do their job very well. But i like the build quality of the longshine one more (small, metal case), i have it like 5 or 6 years now, never had any problems.
Christopher Kruse | Webdeveloper (Interface & Applications)
i7 3770k (3233C Batch) @ 4.2ghz | Asus P8Z77 WS | Gigabyte 780 Ti OC  | Corsair Vengeance LP 1600 32GB DDR3 | Samsung 850 EVO 500GB +2x Samsung 840 EVO 250GB + Samsung 830 256GB + 4x WD30EFRX, 2x WD30EZRX, 1xWD20EARS | Corsair AX750 + Bitfenix Extensions | Fractal Design Define XL R2 + Xigmatec 3in3 Hotswap Cage | Noctua NH-D15 + Thermal Grizzly Kryonaut, 5x Noctua NF-P14s redux-1500 PWM | Peripherals: Logitech G502 + Corsair K70 RGB + Red 40A-L O-Rings | Sound: Denon AVR 2807 via HDMI + 2x Nubert nuPro A-20 + 1x B&W CC6 Center | SoundMagic E10 | Jabra Speak 410
https://linustechtips.com/topic/28861-gigabit-switches/#findComment-366899
My switch is a 24 port gbit but has 2x 10gbit ports or fibre. These would be used to uplink to another switch so if you have more than 1 port at full utilization you won't get throttling or basically bottlenecked.
https://linustechtips.com/topic/28861-gigabit-switches/#findComment-367195
If the switch has 2 gigabit ports and the reset are 100 mb then that means that switch has 2 ports which out of 24 ( if it is a 24 port switch)which are gigabit and those ports are called up link ports, which are means that from either one of those ports, you will have it running to another switch or router which then lets the switch be a part of your network. Not all switches are gigabit. It means that the switch can have a link of gigabit but not all ports are gigabit
https://linustechtips.com/topic/28861-gigabit-switches/#findComment-367201
Not all ports on a switch or router are necessarily the same speed. A switch can have two ports which are faster than the rest (in your case, it has 2Gb port, and the rest are 100Mb ports). It's as simple as that. If you want a gigabit port, make sure that all ports supports up to 1 Gigabit transfer speeds.
The Netgear GS105E and the Netgear GS108NA are examples of switches where all ports are gigabit ports.
By the way, one gigabit is not 1000 bits, it's actually 1,000,000,000 bits. 1000 bits is just 1Kb.
Hope that helped you.
https://linustechtips.com/topic/28861-gigabit-switches/#findComment-369898
How many ports do you want on the Switch
XYPHER AMD FX8350 @ 4.6Ghz ASUS SABERTOOTH 990FX R2.0 AMD RADEON HD 7970 @ 1140Mhz 16GB Corsair VENGEANCE 1600Mhz OCZ VERTEX 3 240GB SSD Corsair H100i 1TB SEAGATE BARRACUDA FRACTAL DESIGN DEFINE R4 CORSAIR K90 MADCATZ RAT 3 iiyama ProLite B2480HS 24"
https://linustechtips.com/topic/28861-gigabit-switches/#findComment-390171
