I am getting the message "To use maximum 3D performance, connect the SLI-ready graphics cards with an SLI connector". It is not detecting my second card, I uninstalled and re-installed the drivers and it has not solved the issue. Could the issue be the SLI Bridge?
Thanks
Build:
i7-4790k OC @ 4.6Ghz
Dual MSI GTX 980s
EVGA 750W G2 Supernova PSU
MSI Gaming 9 AC Mobo
Upcoming build: 4790k OC @ 4.6Ghz, Dual MSI 980 Twin Frozr V, 16 GB Vengeance Pro 2133Mhz RAM, 760T Corsair Case w/ Razer Blackwidow Chroma
https://linustechtips.com/topic/288098-sli-issue/
Have you tried removing the SLI bridge and re attaching it?
|CPU: Intel 5960X|MOBO:Rampage V Extreme|GPU:EVGA 980Ti SC 2 - Way SLI|RAM:G-Skill 32GB|CASE:900D|PSU:CorsairAX1200i|DISPLAY :Dell U2412M X3|SSD Intel 750 400GB, 2X Samsung 850 Pro|
Peripherals : | MOUSE : Logitech G602 | KEYBOARD: K70 RGB (Cherry MX Brown) | NAS: Synology DS1515+  - WD RED 3TB X 5|ROUTER: AC68U
Sound : | HEADPHONES: Sennheiser HD800 SPEAKERS: B&W CM9 (Front floorstanding) ,  B&W CM Center 2 (Centre) | AV RECEIVER : Denon 3806 | MY X99 BUILD LOG!
https://linustechtips.com/topic/288098-sli-issue/#findComment-3912402
Yes, doesn't make a difference unfortunately.
Hmmmm, so it's detecting the card in the Nvidia control panel?
https://linustechtips.com/topic/288098-sli-issue/#findComment-3912407
On Geforce Experience, it notes it as "Unknown", but the card is getting power and showing that it's working, even the fans are moving, but the SLI option on control panel is blocked out and it is not detected.
https://linustechtips.com/topic/288098-sli-issue/#findComment-3912413
Remove the SLI bridge and look again. Is the second card recognized?
https://linustechtips.com/topic/288098-sli-issue/#findComment-3912437
Says "Unknown" still and gives the same message as above.
https://linustechtips.com/topic/288098-sli-issue/#findComment-3912445
Swap cards now.
https://linustechtips.com/topic/288098-sli-issue/#findComment-3912451
make sure mobo is off. just rea someone burnt their mobo.
Do not take life too seriously. You will never get out of it alive.
        :o
https://linustechtips.com/topic/288098-sli-issue/#findComment-3912497
Swap cards now.
Having the same issue, only recognises first card.
https://linustechtips.com/topic/288098-sli-issue/#findComment-3912509
So when you swap cards, the card that was on the bottom before is now recognized?
https://linustechtips.com/topic/288098-sli-issue/#findComment-3912516
Yes.
I believe the issue resides in the second PCIe slot. You can try resetting the CMOS chip by removing the battery, but ultimately, you might need to send your board in for RMA or buy a new one.
https://linustechtips.com/topic/288098-sli-issue/#findComment-3912656
Ah right, thanks for the help!
https://linustechtips.com/topic/288098-sli-issue/#findComment-3912673
Before you RMA the board, check for a BIOS update on the manufacturer website. Out of the box, my ASROCK board wouldn't recognize my second PCI-E slot. After a BIOS update, it recognized all slots and I proceeded like normal.
CompTIA A+ Certified
"We are all cups, quietly and constantly being filled. The trick is knowing how to tip yourself and let the good things pour out." - Ray Bradbury
https://linustechtips.com/topic/288098-sli-issue/#findComment-3914752
Do what RossMadness said FIRST before RMAing a board. RMAs are a pain in the ass and it can often be solved with doing a BIOS update and/or a CMOS clearing.
https://linustechtips.com/topic/288098-sli-issue/#findComment-3914816
Make sure you put it in the correct slot... for my board using a 28 lane CPU, I have to put it in the 3rd slot for it to work properly.
Good luck!
Alex
Thanks for the tips, will check for a BIOS update now and will try re-arranging the GFX cards. Thank you again.
https://linustechtips.com/topic/288098-sli-issue/#findComment-3921613
Good luck!
Alex
The last slot is PCIe x4. SLI doesn't work with those slots.
https://linustechtips.com/topic/288098-sli-issue/#findComment-3921617
