Hey guys!  I was going to buy my build parts today, but the GTX 780 ACX SuperClocked is out of stock now %5Burl=, would it differ if I buy the normal or the superclocked from EVGA OR the one from GIGABYTE? I'm using a water cooler btw so what is the best one for me?
EDIT: or get 2 GTX 770 ? and if yes, which brand?
https://linustechtips.com/topic/28802-please-help/
In my opinion I would just get a normal one, I don't believe they are any better than the standard version they just use a slightly different BIOS to put on a small OC. I have an EVGA superclocked (670) card and it doesn't overclock very well at all.
Save a few bucks and get a normal one.
https://linustechtips.com/topic/28802-please-help/#findComment-366162
Get the single 780 and add another if you need one. If the superclocked is ~$10 more, go for it. Otherwise, stick with the normal one.
https://linustechtips.com/topic/28802-please-help/#findComment-366168
Get the vanilla.  The Superclocks are not binned in any way and you have just as good a chance at getting a good clocker with a vanilla card as with a Superclock.
Intel Core i7 4930K @ 4.7GHz | Asus Rampage IV Extreme | 2 x EVGA GTX Titan SC (1254MHz) | 16GB Patriot Viper Extreme DDR3 2133MHz (4 x 4GB) | Corsair AX1200 | Silverstone Temjin TJ11 | Corsair Force 3 240GB (System) | 2 x Intel 320 160GB SSD (Dedicated Gaming Drives) | Hitachi Deskstar 1TB (Data) | MS Windows 10 Pro | EK Supreme HF/FC-Titan/Rampage IV Extreme blocks | Hardware Labs GTX 560/240 rads | Alphacool VPP-655 D5 pump | Bitspower mod kit/pump top/fittings/120mm res
https://linustechtips.com/topic/28802-please-help/#findComment-366595
@d33g33 @WoodenMarker @MegaTechPC, okay now what to get? 1 780 or 2 770?
Hard to answer because they don't come in at the same price point.
If it was my money and i very well may be going down this street shortly, I would rather buy a 780 and add another later than get 2x 770's now.
DeeG
https://linustechtips.com/topic/28802-please-help/#findComment-367334
