I want to do a PC table:
here my PC:
core i7 4770k
Asus hero vi
Asus gtx 780 oc
4X2 ram [corsair] I am going to upgrade
4tb
240 ssd
and I want to put a custom water cooling.
i am going to buy from ebay...
and i have 2 C:
1. Is it worth for CPU and gpu??
2.I need a recommendation about it where to  buy.
here something I think is ok please help!
http://www.ebay.com/itm/Water-Cooling-Kit-360-Copper-Radiator-CPU-GPU-NB-Block-14w-Pump-190mm-Reservoir/231172583033?_trksid=p2047675.c100010.m2109&_trkparms=aid%3D555012%26algo%3DPW.MBE%26ao%3D1%26asc%3D20131231084308%26meid%3D0ceb33206aed402ea508c5b647d7c63a%26pid%3D100010%26prg%3D20131231084308%26rk%3D1%26rkt%3D24%26mehot%3Dpp%26sd%3D171387264622
https://linustechtips.com/topic/287577-custom-water-cooling-pc/
Have you ever done watercooling before? Have you ever worked with wood before?
If no to either of those questions, don't do this. There's a prebuilt desk on the market I believe and you should start there.
I am doing this With a friend it's ok I need to know if its ok up what I wrote
https://linustechtips.com/topic/287577-custom-water-cooling-pc/#findComment-3905110
