You sure you have a 4790k and not a 4790?
LanSyndicate Build | i5-6600k | ASRock OC Formula | G.Skill 3600MHz | Samsung 850 Evo | MSI R9-290X 8GB Alphacool Block | Enthoo Pro M | XTR Pro 750w | Custom Loop |
Daily | 5960X | X99 Sabertooth | G.Skill 3000MHz | 750 NVMe | 850 Evo | x2 WD Se 2TB | x2 Seagate 3TB | Sapphire R9-290X 8GB | Enthoo Primo | EVGA 1000G2 | Custom Loop |
Game Box | 4690K | Z97i-Plus | G.Skill 2400MHz | x2 840 Evo | GTX 970 shorty | Corsair 250D modded with H105 | EVGA 650w B2 |
https://linustechtips.com/topic/287228-i-need-overclocking-help/#findComment-3900484
your right I ordered the wrong one when I got it on amazon because they were right next to each other :( thanks for the help anyways.
If you got it with Amazon just return and get the right one :)
https://linustechtips.com/topic/287228-i-need-overclocking-help/#findComment-3900608
