Hard Drive Test
Go to solution Solved by TakeiT,
Thanks, guys.
Does anyone know of a good free piece of software to test how well my hard drive is functioning?  I've got a feeling that it is dying (It's incredibly slow, and i've just formatted it).  I'd like to be able to test if my suspicions are true.  Maybe a program that shows a meter of how well its performing?
https://linustechtips.com/topic/287186-hard-drive-test/
Crystaldiskinfo. Crystaldiskmark.
https://linustechtips.com/topic/287186-hard-drive-test/#findComment-3899560
Crystal Disk Info can show you info about its health. They also have a other program,Crystal Disk Mark, to test speeds.
CPU i7-9700K @ 5 GHz Motherboard ASUS ROG Strix Z390-F RAM Corsair Vengeance 32 GB (4x8) 3000 MHz GPU ASUS RTX 2080 ROG Strix OC x2 SLI Case Corsair Graphite 780T Storage 256 GB Samsung 860 EVO, 6 TB Seagate Barracuda PSU Corsair HX1200i, 1200W Display(s) ASUS PG279Q (1440p 165 Hz), ASUS VG248QE (1080p 144 Hz) Cooling ASUS ROG Ryujin 360 radiator Keyboard Logitech G710+ Mouse Logitech G502 Sound Logitech G35 Operating System Windows 10
https://linustechtips.com/topic/287186-hard-drive-test/#findComment-3899562
I think Speefan gives SMART data. So do a lot of other programs.
Prometheus (Main Rig)
CPU-Z Verification
Laptop:
Intel Core i3-5005U, 8GB RAM, Crucial MX 100 128GB, Touch-Screen, Intel 7260 WiFi/Bluetooth card.
 Phone:
 Game Consoles:
Softmodded Fat PS2 w/ 80GB HDD, and a Dreamcast.
If you want my attention quote my post, or tag me. If you don't use PCPartPicker I will ignore your build.
https://linustechtips.com/topic/287186-hard-drive-test/#findComment-3899639
Hey TakeiT,
What HDD do you own? Usually each manufacturer has their own tool to do that and I always recommend it since they are tuned specifically for the manufacturer's own drives and best know the firmware. For example, Western Digital has WD Data Lifeguard Diagnostic tool to do the checking of all WD drives. These tools are usually free. :)
Captain_WD.
If this helped you, like and choose it as best answer - you might help someone else with the same issue. ^_^
WDC Representative, http://www.wdc.com/
https://linustechtips.com/topic/287186-hard-drive-test/#findComment-3904832
I ran a test with crystaldiskinfo, it said the health is good but i've got 5580 hours on the drive.  It's a seagate laptop drive.  Anyone know the average lifespan of one of these?
if its a laptop drive it could be 2.5" drive running at 4500rpm? and maybe even Sata 2 ( 3gigs/sec)
so even if you have done a fresh install it will still be slow compared to a sata 3 drive.
got to love Asus components
https://linustechtips.com/topic/287186-hard-drive-test/#findComment-3912319
Are you sure SATA II and III matters on HDD's? I think only SSD's will experience bottlenecks using the former (also the latter if you think about it but let's gloss over that)
I cannot be held responsible for any bad advice given.
I've no idea why the world is afraid of 3D-printed guns when clearly 3D-printed crossbows would be more practical for now.
My rig: The StealthRay. Plans for a newer, better version of its mufflers are already being made.
https://linustechtips.com/topic/287186-hard-drive-test/#findComment-3912731
@TakeiT Why is 5600 hours a concern? That's barely broken in. I have almost 5K on my drives and the system is only 6 mths old. 556k hours would be a cause for concern perhaps.
Sir William of Orange: Corsair 230T - Rebel Orange, 4690K, GA-97X SOC, 16gb Dom Plats 1866C9,  2 MX100 256gb, Seagate 2tb Desktop, EVGA Supernova 750-G2, Be Quiet! Dark Rock 3, DK 9008 keyboard, Pioneer BR drive. Yeah, on board graphics - deal with it!
https://linustechtips.com/topic/287186-hard-drive-test/#findComment-3913097
Usually a HDD's performance wouldn't change much if you go from SATA2 to SATA3 as HDDs hardly utilize SATA2 port's limits. There are differences, though, between the performance of a drive that is hooked on a SATA2 port and the same drive that is hooked on a SATA3 port:
-The burst speed is greater in SATA III configuration.
-The read speeds for file benchmarks are generally greater in SATA III configuration.
It basically means that you could see a bit of an improvement in SATA3 when transferring small files (smaller than your drive's cache size). Once the files become larger, there would hardly be any differences between the usage of the two ports (it would be around 1% difference in speed).
Captain_WD.
https://linustechtips.com/topic/287186-hard-drive-test/#findComment-3930555
At nearly 5600 hours, I'd like to know what the chances of the drive failing are.  I'm thinking of popping an SSD into it, but its only a computer i use sometimes, and it needs other things too.  Should I make that a priority?
Not even close.
Most drives have a MTBF of 300,000 hours (or more). You are only at ~5,600 hours.
AMD Ryzen 9000 Rig
  • Lian-Li O11 Dynamic EVO XL
AMD Ryzen 5000 Rig
  • AMD R7-5800X
  • Gigabyte B550 Aorus Pro AC
  • EKwb D-RGB 360mm AIO
https://linustechtips.com/topic/287186-hard-drive-test/#findComment-3934921
