Use.dots.like.a.pro.
RMA your keyboard?
https://linustechtips.com/topic/287172-mechanicalspacebroke/#findComment-3899272
RMA? How'd you break it?
Prometheus (Main Rig)
CPU-Z Verification
Laptop:
Intel Core i3-5005U, 8GB RAM, Crucial MX 100 128GB, Touch-Screen, Intel 7260 WiFi/Bluetooth card.
 Phone:
 Game Consoles:
Softmodded Fat PS2 w/ 80GB HDD, and a Dreamcast.
If you want my attention quote my post, or tag me. If you don't use PCPartPicker I will ignore your build.
https://linustechtips.com/topic/287172-mechanicalspacebroke/#findComment-3899276
Used.keyboard.:/
Take the space bar off, clean the switches.
How.do.i.clean.the.switches?
https://linustechtips.com/topic/287172-mechanicalspacebroke/#findComment-3899312
Do you have a compressor? Blow out the switch
My Main Build: NZXT S340 - NZXT Kraken X31 - Crucial MX100 256GB - i5 4460 - Gigabyte Z97P D3 - Kingston HyperX Red 8GB - MSI Nvidia GTX 780 3GB - Corsair LL & HD RGB Fans, Corsair Lighting Node Pro.
https://linustechtips.com/topic/287172-mechanicalspacebroke/#findComment-3899344
try unplugging it and plugging it back in. it seems silly but it could work, static discharge is weird.
Tried.that.AND.restarting.to.no.avail
https://linustechtips.com/topic/287172-mechanicalspacebroke/#findComment-3899365
can always replace the switches themselves as a last resort effort if easier fixes dont work.
How.much.and.where.from?
I.hit.it.but.not.hard
I.used.to.beat.the.shit.out.of.my.lycosa.and.it.still.worked.while.this.was.more.of.an.angry.tap
https://linustechtips.com/topic/287172-mechanicalspacebroke/#findComment-3899384
That shouldn't have broke it. Mechanical boards are robust. Might be fixable by cleaning, but most likely broke.
CPU-Z Verification
Laptop:
 Phone:
 Game Consoles:
https://linustechtips.com/topic/287172-mechanicalspacebroke/#findComment-3899401
I.bought.it.used.but.he.was.a.trusted.user.and.it.came.in.great.condition.
I.PAID.EXTRA.SO.THIS.WOULDN'T.HAPPEN
https://linustechtips.com/topic/287172-mechanicalspacebroke/#findComment-3899424
Did it work before you hit it?
CPU-Z Verification
Laptop:
 Phone:
 Game Consoles:
https://linustechtips.com/topic/287172-mechanicalspacebroke/#findComment-3899429
lots of sites online sell just the switches...all kinds of mechanical keyboard parts just look and find the best price delivered. easy google search.
https://linustechtips.com/topic/287172-mechanicalspacebroke/#findComment-3899442
Yup.Literally.no.problems.worked.perfectly.
Then it wasn't his fault. You can try replacing the switch.
CPU-Z Verification
Laptop:
 Phone:
 Game Consoles:
https://linustechtips.com/topic/287172-mechanicalspacebroke/#findComment-3899447
Any.other.way?
I.don't.understand.what.people.mean.by.cleaning.it?
https://linustechtips.com/topic/287172-mechanicalspacebroke/#findComment-3899458
Any.other.way?
Watch Pauls Hardware's video on cleaning a mechanical keyboard.
CPU-Z Verification
Laptop:
 Phone:
 Game Consoles:
https://linustechtips.com/topic/287172-mechanicalspacebroke/#findComment-3899467
If.this.doesn't.work.is.there.any.other.way?
https://linustechtips.com/topic/287172-mechanicalspacebroke/#findComment-3899691
