Hi boys and girls,
Im planning to buy a new monitor. Im coming from two 24" monitors, and want to downsize to one 27".
Im a mild gamer. My graphics card is a gtx970.
Preferences:
TN panel
Low ms
no need for higher res than 1080p
27"
no need for 144hz so 60hz i think is preferable.
(dont think g-sync is an option here but it would be nice?)
I did some research myself but i like some second opinions.
Budget remains open depens or what the advice is going to be.
Thanks!
https://linustechtips.com/topic/287128-need-some-advice/
I used Acer a lot in the last couple of years and I never had any problems with them.
So I would recommend the Acer G6 G276H http://geizhals.de/acer-g6-g276hlabid-um-hg6ee-a01-a768753.html
Sorry, for the german link, was too lazy to find a english one.
  • Full HD 1920x1080
  • 27 inch
  • 2ms response time
  • TN panel
  • HDMI, VGA, DVI
  • Vesa mount compatible
https://linustechtips.com/topic/287128-need-some-advice/#findComment-3898864
So I would recommend the Acer G6 G276H http://www.amazon.com/Acer-G276HL-Dbmid-27-Inch-LED-Backlit/dp/B0098Y77LE/ref=sr_1_1?ie=UTF8&qid=1420749956&sr=8-1&keywords=Acer+G6+G276H
  • Full HD 1920x1080
  • 27 inch
  • 2ms response time
  • TN panel
  • HDMI, VGA, DVI
I see the word vesa come around alot in my search. But what is is actually?
https://linustechtips.com/topic/287128-need-some-advice/#findComment-3898892
Btw.: I changed the link. The other one was rong.
A VESA mount is a simple standard to fit VESA compatible stands or wall mounts.
VESA usually means that there are 4 holes drilled in the back of your monitor, each one at a distance of either 100 or 200mm from each other.
Looks like this:
tether-tools-tethered-photography-Go-Vu-
https://linustechtips.com/topic/287128-need-some-advice/#findComment-3898936
  • Full HD 1920x1080
  • 27 inch
  • 2ms response time
  • TN panel
  • HDMI, VGA, DVI
Btw, its kind of a cheap monitor...? No other reccomendations? If it even benefits the monitor ofcourse.
https://linustechtips.com/topic/287128-need-some-advice/#findComment-3898978
There are a lot of monitors out there. I took this one because it's pretty cheap. It does the things you need and why would you want to pay more than that. But here is a list of all monitors that have the things you need. 27 inch, 2ms response time, full HD.
In general I recommend Acer, Asus, Samsung and BenQ
http://geizhals.de/?cat=monlcd19wide&xf=99_27~1455_27~5137_1920x1080~104_2#xf_top
https://linustechtips.com/topic/287128-need-some-advice/#findComment-3899032
