Im thinking of building my own gaming pc on a budget and this is what a got so far.
Any suggestions and recommendations are very welcome!
PCPartPicker part list: http://pcpartpicker.com/p/nwLvvK
CPU: AMD FX-6350 3.9GHz 6-Core Processor  ($119.99 @ Amazon)
CPU Cooler: Corsair H55 57.0 CFM Liquid CPU Cooler  ($64.99 @ Newegg)
Motherboard: MSI 970 GAMING ATX AM3+ Motherboard  ($99.89 @ Newegg)
Memory: G.Skill Ares Series 8GB (2 x 4GB) DDR3-1600 Memory  ($69.99 @ Newegg)
Storage: Seagate Barracuda 1TB 3.5" 7200RPM Internal Hard Drive  ($49.88 @ OutletPC)
Video Card: MSI Radeon R9 270X 2GB TWIN FROZR Video Card  ($154.99 @ Newegg)
Case: Cooler Master N400 ATX Mid Tower Case  ($44.99 @ Micro Center)
Power Supply: Corsair CX 600W 80+ Bronze Certified Semi-Modular ATX Power Supply  ($53.99 @ NCIX US)
Operating System: Microsoft Windows 8.1 (OEM) (64-bit)  ($89.98 @ OutletPC)
Total: $737.69
Generated by PCPartPicker 2015-01-08 08:51 EST-0500
https://linustechtips.com/topic/286929-first-build-help/
Looks wonderful, that will be a quite good gaming machine. It all looks good.
Intel Core i7-5820K (4.4 GHz) | Gigabyte GTX 970 G1 Gaming | Corsair Vengeance LPX 16GB  | 2x 360mm Custom Loop (Noctua iPPC) | ASRock X99 Extreme6 | Samsung 840 EVO 250GB | Fractal Design Define S | Corsair HX750 | Windows 10 | Corsair M65 RGB PRO | Corsair K70 RGB LUX (CherryMX Brown) | Beyerdynamic Custom One Pro & Creative Sound Blaster Z | Nexus 6P (32GB Aluminium) | Check out my setup: Project Kalte Here!
https://linustechtips.com/topic/286929-first-build-help/#findComment-3895735
https://linustechtips.com/topic/286929-first-build-help/#findComment-3895736
Ew biostar
Give me a moment to see if I can do better @RickA
RIG: I7-4790k @ 4.5GHz | MSI Z97S SLI Plus | 12GB Geil Dragon RAM 1333MHz | Gigabyte G1 Gaming GTX 970 (1550MHz core/7800MHz memory) @ +18mV(Maxed out at 1650/7800 so far) | Corsair RM750 | Samsung 840 EVO 120GB, 1TB Seagate Barracuda | Fractal Design Arc Midi R2 (Closed) | Sound Blaster Z        Getting: Noctua NH-D15 | Possible 250GB Samsung 850 Evo        Need a console killer that actually shits on every console? Here you go (No MIR/Promo)
This is why you should not get an FX CPU for ANY scenario other than rendering on a budget http://linustechtips.com/main/topic/286142-fx-8350-r9-290-psu-requirements/?p=3892901 http://linustechtips.com/main/topic/266481-an-issue-with-people-bashing-the-fx-cpus/?p=3620861
https://linustechtips.com/topic/286929-first-build-help/#findComment-3895743
@RickA
CPU: Intel Core i5-4440 3.1GHz Quad-Core Processor  ($174.99 @ SuperBiiz)
Motherboard: MSI H81M-P33 Micro ATX LGA1150 Motherboard  ($44.99 @ Directron)
Video Card: Sapphire Radeon R9 290 4GB Tri-X Video Card  ($268.99 @ SuperBiiz)
Case: NZXT Source 210 (Black) ATX Mid Tower Case  ($29.98 @ OutletPC)
Power Supply: EVGA 600B 600W 80+ Bronze Certified ATX Power Supply  ($34.99 @ Newegg)
Total: $764.78
Generated by PCPartPicker 2015-01-08 09:00 EST-0500
Is what I could do, doubt you can find a better build for the money than this
https://linustechtips.com/topic/286929-first-build-help/#findComment-3895758
@RickA
Total: $764.78
You always can (currency change)
https://linustechtips.com/topic/286929-first-build-help/#findComment-3895770
@RickA
Total: $764.78
Pretty much what I would have taken. ;-)
And it will even give you mid-range 4k performance, something a 270X will not even get close to.
PC: AMD Ryzen 7 7700 || Noctua NH-U12S SE2 || 32GB DDR5 6000 CL32  ||
|| Powercolor RX 9070 Reaper || Asus B650E-I
  || WD 850X 2TB ||  Corsair SF600 || Intertech IM 1 |||
Peripherals: Sennheiser PC  360 G4ME || AOC CQ27G2U || Viewsonic PX701HD || Keychron V1 || Logitech G303 Shroud Edition||| Laptop: XPS 13 2in1 7390 || Steam Deck 256 GB (64GB Version) ||| Cameras: Fujifilm XH-1 || Fujifilm X100T
Elite 110 build log (update:05/15/2018)
https://linustechtips.com/topic/286929-first-build-help/#findComment-3895773
@RickA
Total: $764.78
Why a core i5 instead of a AMD processor
https://linustechtips.com/topic/286929-first-build-help/#findComment-3895794
Read the links in my signature and you will understand
@RickA
https://linustechtips.com/topic/286929-first-build-help/#findComment-3895798
The i5 performs better for gaming due to the faster cores.
https://linustechtips.com/topic/286929-first-build-help/#findComment-3896006
even tho I like AMD mostly becase it's better for budget gaming Intel CPU's for the most part are better due to faster cores even tho for gaming the CPU is. It that important it's the GPU becase my old core 2 duo paird with I forgot what gpu but it ran a lot of game not new games older ones like from 2011
https://linustechtips.com/topic/286929-first-build-help/#findComment-3896230
