Software to control cpu fan speed
Go to solution Solved by FoxHound,
is there software I can use to control my cpu fan?  msi b85 g41 and i5 4570.  If there is no software, is there a setting in the bios?
MSI offers a Command Center that should have all the control you need for your fans.
You should be able to control the fan speeds using the uefi bios.
Open Hardware Monitor allows you to control some fan speeds and monitor system temps.
do u mean the cpuid hwmonitor or is there a windows one.  if so, where is the one ur talking about
I can help with programming and hardware.
<Script>alert("This website is vulnerable to XSS");</Script>
Quantum Chaos: i7 6850K | 2x Strix 1080Ti SLI | MSI X99 SLI Krait | 32GB Corsair Vengeance LPX | Samsung 970 EVO 500GB | 3TB WD Red RAID 1
http://openhardwaremonitor.org/
My arsenal: i7-9700k Gaming Rig, an iPhone, and Stupidity.
