This will kind of stretch your budget but is a very high quality PSU, I use it in my system:
http://www.newegg.com/Product/Product.aspx?Item=N82E16817151087&cm_re=SeaSonic_Power_Supply-_-17-151-087-_-Product
Another one you could go with is less expensive ($20 less) but is 100W less, but should still be fine for your build:
http://www.newegg.com/Product/Product.aspx?Item=N82E16817151088&cm_re=seasonic_psu-_-17-151-088-_-Product
Specs: i3 4150 (hopefully soon to be upgraded), GTX 750Ti (Again, hopefully soon to be upgraded), Gigabyte G1 Sniper Z97 motherboard, G.Skill 8GB 1600MHz DDR3 memory, WD Blue 1TB HDD, Cooler Master Hyper 212 Evo, Corsair Obsidian 450D, Seasonic X-series 750W 80+ Gold PSU.
