Hello all.
I'm planning on building a Gaming rig that would be able to handle the Oculus rift DK2 (As mentioned before).
My current idea is:
CPU - Intel i3-4130 (i3 to take advantage of hyperthreading, i5 CPUs cannot)
GPU - Radeon R9 280x
RAM - 8GB DDR3
Would this combo push most titles at 1080, 75FPS?
Fine you want the PSU tier list? Have the PSU tier list: https://linustechtips.com/main/topic/1116640-psu-tier-list-40-rev-103/
Stille (Desktop)
Ryzen 9 3900XT@4.5Ghz - Cryorig H7 Ultimate - 16GB Vengeance LPX 3000Mhz- MSI RTX 3080 Ti Ventus 3x OC - SanDisk Plus 480GB - Crucial MX500 500GB - Intel 660P 1TB SSD - (2x) WD Red 2TB - EVGA G3 650w - Corsair 760T
Evoo Gaming 15"
i7-9750H - 16GB DDR4 - GTX 1660Ti - 480GB SSD M.2 - 1TB 2.5" BX500 SSD
VM + NAS Server (ProxMox 6.3)
1x Xeon E5-2690 v2  - 92GB ECC DDR3 - Quadro 4000 - Dell H310 HBA (Flashed with IT firmware) -500GB Crucial MX500 (Proxmox Host) Kingston 128GB SSD (FreeNAS dev/ID passthrough) - 8x4TB Toshiba N300 HDD
Toys: Ender 3 Pro, Oculus Rift CV1, Oculus Quest 2, about half a dozen raspberry Pis (2b to 4), Arduino Uno, Arduino Mega, Arduino nano (x3), Arduino nano pro, Atomic Pi.
https://linustechtips.com/topic/286410-oculus-rift-dk2-build/
If you are building an Oculus rig; get a 970 or 980 since it has features that help with motion sickness.
Want a good game to play?  Check out Shadowrun: http://store.steampowered.com/app/300550/ (runs on literally any hardware)
another 12 core / 24 thread senpai...     (/. _ .)/     \(. _ .\)
https://linustechtips.com/topic/286410-oculus-rift-dk2-build/#findComment-3888818
i5 is still faster though.  :lol:
https://linustechtips.com/topic/286410-oculus-rift-dk2-build/#findComment-3888836
Hello all.
My current idea is:
RAM - 8GB DDR3
hyperthreading does not help whit gaming a lot. save the money and get a Pentium whit the other money you can get a 970 or 980.
the reason for this you can read down here.
https://linustechtips.com/topic/286410-oculus-rift-dk2-build/#findComment-3888839
My budget doesn't lend the money to get the 970 or 980.  :(
Also, I know gaming cannot take advantage of hyperthreading, but the processing lanes can be used in the SDK.
Stille (Desktop)
Evoo Gaming 15"
https://linustechtips.com/topic/286410-oculus-rift-dk2-build/#findComment-3888866
Would going for an AMD CPU (FX or Athlon) be a better use of my money? (I want more than two logical cores)
Stille (Desktop)
Evoo Gaming 15"
https://linustechtips.com/topic/286410-oculus-rift-dk2-build/#findComment-3888910
i3 is definitely more powerful than pentium, even OC'ed one. Pentium<i3<5.
https://linustechtips.com/topic/286410-oculus-rift-dk2-build/#findComment-3888957
yes, but for gaming you can do with a pentium g3258 and get better performance with a 970. and later down the line you can drop in a 4690K to get the fully unlocked quad core experience.
https://linustechtips.com/topic/286410-oculus-rift-dk2-build/#findComment-3889647
and when you want to run ubishit titles your pc is worse than xbox
https://linustechtips.com/topic/286410-oculus-rift-dk2-build/#findComment-3889655
@ili199, I don't have the money to put a 970 in my system. And I already ruled out the G3258. I have a dual core laptop, and its not enough for the rift. I want at least 4 logical cores for my desktop.
Stille (Desktop)
Evoo Gaming 15"
https://linustechtips.com/topic/286410-oculus-rift-dk2-build/#findComment-3889684
What is your total buged and were do you live? then we can try to make a pcpartpicker list for you.
https://linustechtips.com/topic/286410-oculus-rift-dk2-build/#findComment-3889852
Total budget is around 500-550, but I already have a case, 600w PSU, and HDD, so I'm hoping to put all of that cash into the mobo, CPU, GPU, and RAM.
Stille (Desktop)
Evoo Gaming 15"
https://linustechtips.com/topic/286410-oculus-rift-dk2-build/#findComment-3889882
I'm also thinking of a AMD FX-6300 and the 280x or a 770
Stille (Desktop)
Evoo Gaming 15"
https://linustechtips.com/topic/286410-oculus-rift-dk2-build/#findComment-3890293
