Currently i have been using a Razer Ouroboros Wireless/Wired hybrid thing.
I have come to hating this thing not because of bad hardware but because of poor build quality and design. Maybe I'm just hard on mice, But this was my first High-end Mouse and its already falling apart after about 11 months.The rechargeable battery for the wireless half is already shot: even at new it didn't last too long, The Textured grip material on the side with my thumb is already wearing off pretty badly, and it sometimes just decides to lose connection to my computer even though its plugged in all the time now.
Temporarily i got a Razer Hex for the extra buttons and its Compatible with my Razer Profiles from my other mouse but i need a solid replacement.
Can Anyone Suggest a  decent mouse (that isn't a Razer) that has at least three Function Buttons (excluding left,right, and middle click)?
Current: R2600X@4.0GHz\\ Corsair Air 280x \\ RTX 2070 \\ 16GB DDR3 2666 \\ 1KW EVGA Supernova\\ Asus B450 TUF
Old Systems: A6 5200 APU -- A10 7800K + HD6670 -- FX 9370 + 2X R9 290 -- G3258 + R9 280 -- 4690K + RX480
https://linustechtips.com/topic/286295-mouse-replacement/
I'd check out things like the Corsair M65 / M95 (did you say Macros?) or the Steelseries Kana / Steelseries Kinzu / Minoix Avior / Mionix Naos mice. Ofcourse there is also Logitech, but I don't give them much attention personally.
NCASE M1 i5-12600kf  RTX 4060Ti FE Z690M-ITX  SF600 NH-L9x65 Chromax  LPX 32GB
https://linustechtips.com/topic/286295-mouse-replacement/#findComment-3887487
Loving my logitech g502!
I also really like the Roccat tyon
https://linustechtips.com/topic/286295-mouse-replacement/#findComment-3887508
The Logitech G502 Looks like it has a lot of nice features but for my peripherals I'm extra picky about aesthetics and its the total opposite color of the rest of my build.
But that's my only complaint about it.
https://linustechtips.com/topic/286295-mouse-replacement/#findComment-3888350
I can't recommend the Shogun bros Ballista enough,
it's got 4 function button (6 if you include the scrollwheel side click) and 5 profiles can be setup and quickly switched between,
It's comfortable unless you have tiny hands, or are a massive claw gripper
https://linustechtips.com/topic/286295-mouse-replacement/#findComment-3909478
