Hi there :)
I've got a Cooler Master Hyper 101 and currently pushing air with the stock fan and pulling with a Noctua NF-8.
They have the same CFM but the Noctua has lower static pressure. Is this a good setup? Thanks for the help!
Here's the spec sheets if they're of any help
Hyper 101 :http://www.coolermaster.com/product/Detail/cooling/cpu-air-cooler/hyper-101.html
NF-R8 : http://www.noctua.at/pdf/infosheets/noctua_nf_r8_pwm_datasheet_en.pdf
Personal Rig
i7 4790K | Asus Z97I-WiFi | CM 280L | Sapphire R9 290X Tri-X | Kingston ValueRAM 2 x 8GB | 128GB Samsung 840 Pro | 2TB Seagate SSHD | Seasonic Platinium 660W | Bitfenix Prodigy
https://linustechtips.com/topic/28584-pushpull-with-different-fans/
Hi there :)
Well it's Noctua, they know their shit. I think it should be good for now.
I'm using like 1xNZXT fan and 1xCorsair fan for my crappy H60 atm.
Intel i7-2600K @ 4,5GHz | EVGA GeForce GTX 780 w/EKWB Copper Waterblock | Kingston HyperX blu 16GB @ 1600 MHz | Phanteks Enthoo Primo | MSI Z77A-GD65 | CM M1000 Silent Pro | Samsung 840 Pro 128GB | BenQ XL2420T 120hz | Logitech G710+ | Razer Deathadder 2013 -
- XSPC Raystorm CPU Waterblock | XSPC RX360 Radiator | EKWB EK-FC Titan GPU Waterblock -
I WOULD THINK THAT AIR PREASURE AND AIR FLOW WITH THE LEAST AMOUNT OF AIR LEAKAGE SO I WOALD GO FOR TWO OF THE SAME MODAL # ( LIKE NOCTUAS OR COOLMASTER ) FOR THE EFICENCY OF THE COMPUTER
and now say that again without all caps
I7 3930K @4.4 GHz  /  Asus rampage 4 formula  / 4x 8gb kingston hyperx blue low profile / gtx 980  / 2x ssd 500gb samsung 840 / 500gb 840evo ssd   /  500 GB WD blue /  windows 7 ultimate
my build: http://linustechtips.com/main/topic/133477-750d-finished/
Point taken but no need for caps lol.
Personal Rig
I generally wouldn't use different fans for push/pull since you can create turbulence if they're running at different RPM's, but it depends on the fans though I guess.
Stop shouting at me! :(
