What's up guys. So I am kinda new to PC gaming, and I was wondering if I could get some help with parts and such, I'm hoping to spend no more than $1400
This is the monitor I have been looking at:  http://www.amazon.com/dp/B00FJCNWYA/ref=wl_it_dp_o_pd_nS_ttl?_encoding=UTF8&colid=34N0I7XT8PO09&coliid=ISAPGZ1YRZ3UD&psc=1
If you guys could suggest some parts, that would be awesome, thanks :)
https://linustechtips.com/topic/285746-budget-build-pc-help/
That monitor has a 6ms response time, I would look at 1ms response time monitors. Also, is the monitor included in your budget ($1400)?
https://linustechtips.com/topic/285746-budget-build-pc-help/#findComment-3879739
I'm not looking to play a whole lot of FPS games, otherwise, yes I would pick a different one. Haha. And no, the monitor is separate from the budget of the PC build.
https://linustechtips.com/topic/285746-budget-build-pc-help/#findComment-3879767
CPU: Intel Core i5-4690K 3.5GHz Quad-Core Processor  ($219.99 @ SuperBiiz)
CPU Cooler: Cooler Master Hyper 212 EVO 82.9 CFM Sleeve Bearing CPU Cooler  ($28.75 @ OutletPC)
Motherboard: MSI Z97S SLI Plus ATX LGA1150 Motherboard  ($90.98 @ Newegg)
Memory: G.Skill Ripjaws X Series 8GB (2 x 4GB) DDR3-1600 Memory  ($80.98 @ Newegg)
Storage: Crucial MX100 256GB 2.5" Solid State Drive  ($104.99 @ SuperBiiz)
Storage: Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive  ($52.85 @ OutletPC)
Video Card: EVGA GeForce GTX 970 4GB FTW ACX 2.0 Video Card (2-Way SLI)  ($369.99 @ SuperBiiz)
Case: Thermaltake Commander MS-I ID ATX Mid Tower Case  ($34.99 @ Micro Center)
Power Supply: SeaSonic 620W 80+ Bronze Certified Fully-Modular ATX Power Supply  ($54.99 @ Amazon)
Total: $1408.50
Generated by PCPartPicker 2015-01-06 14:07 EST-0500
https://linustechtips.com/topic/285746-budget-build-pc-help/#findComment-3879777
CPU: i5-4690k GPU: 280x Toxic PSU: Coolermaster V750 Motherboard: Z97X-SOC RAM: Ripjaws 1x8 1600mhz Case: Corsair 750D HDD: WD Blue 1TB
How to Build A PC|Windows 10 Review Follow the CoC and don't be a scrub~soaringchicken
https://linustechtips.com/topic/285746-budget-build-pc-help/#findComment-3879822
Total: $1408.50
Thank you! Really appreciate it.
https://linustechtips.com/topic/285746-budget-build-pc-help/#findComment-3879825
Budget Location: US. $1400 I could go a little higher if necessary
Aim: Strictly for gaming
Monitors: A single  Nixeus Vue 27" IPS LED 2560x1440
Peripherals: Got it covered
PCPartPicker part list: http://pcpartpicker.com/p/ZLwN99
Price breakdown by merchant: http://pcpartpicker.com/p/ZLwN99/by_merchant/
CPU Cooler: NZXT Kraken X61 106.1 CFM Liquid CPU Cooler  ($123.99 @ SuperBiiz)
Motherboard: Asus Z97-A ATX LGA1150 Motherboard  ($129.99 @ Amazon)
Memory: Kingston Fury Black Series 8GB (2 x 4GB) DDR3-1866 Memory  ($73.99 @ Newegg)
Storage: Samsung 840 EVO 250GB 2.5" Solid State Drive  ($123.87 @ OutletPC)
Storage: Seagate Barracuda 2TB 3.5" 7200RPM Internal Hard Drive  ($77.75 @ OutletPC)
Video Card: Gigabyte GeForce GTX 980 4GB WINDFORCE 3X Video Card  ($557.99 @ B&H)
Case: NZXT H440 (Black/Red) ATX Mid Tower Case  ($108.99 @ SuperBiiz)
Power Supply: Corsair CX 600W 80+ Bronze Certified Semi-Modular ATX Power Supply  ($54.99 @ Newegg)
Operating System: Microsoft Windows 8.1 (OEM) (64-bit)  ($89.98 @ OutletPC)
Total: $1561.53
Generated by PCPartPicker 2015-01-06 14:16 EST-0500
this one has os in it. but i you don't need an os then it would go down to around 1400$
PC: CPU: Ryzen 5 5600X @ Curve optimzer -25,  Cooler: Noctua NH-D15 Chromax.Black, Motherboard: Asus Rog Strix B500-F Gaming WiFi II, GPU: Sapphire Nitro+ RX 7800XT @ Stock , RAM: G.Skill Trident Z RGB 2x16GB DDR4 3600Mhz CL18, HDD: Western Digital Caviar Black 2TB, SSD: Samsung 850 Evo 250GB | Team Group MP33 1TB NVME, Case: NZXT H7 Flow Black, PSU: NZXT C1200  I Peripherals: Keyboard: Ducky Shine 6 RGB Special Edition, Mouse: Razer Orochi V2, Headset: Philips SHP9500, Mousepad: Glorious Stealth Extended I Laptop: MSI GS63VR Stealth Pro CPU: i7-6700HQ@ 2.6ghz, GPU: GTX 1060, Memory: 16GB DDR4 2400Mhz, HDD: 1TB+128GB SSD
https://linustechtips.com/topic/285746-budget-build-pc-help/#findComment-3879851
PCPartPicker part list / Price breakdown by merchantCPU: Intel Core i5-4690K 3.5GHz Quad-Core Processor  ($219.99 @ SuperBiiz)CPU Cooler: Cooler Master Hyper 212 EVO 82.9 CFM Sleeve Bearing CPU Cooler  ($28.75 @ OutletPC)Motherboard: MSI Z97S SLI Plus ATX LGA1150 Motherboard  ($90.98 @ Newegg)Memory: G.Skill Ripjaws X Series 8GB (2 x 4GB) DDR3-1600 Memory  ($80.98 @ Newegg)Storage: Crucial MX100 256GB 2.5" Solid State Drive  ($104.99 @ SuperBiiz)Storage: Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive  ($52.85 @ OutletPC)Video Card: EVGA GeForce GTX 970 4GB FTW ACX 2.0 Video Card (2-Way SLI)  ($369.99 @ SuperBiiz)Video Card: EVGA GeForce GTX 970 4GB FTW ACX 2.0 Video Card (2-Way SLI)  ($369.99 @ SuperBiiz)Case: Thermaltake Commander MS-I ID ATX Mid Tower Case  ($34.99 @ Micro Center)Power Supply: SeaSonic 620W 80+ Bronze Certified Fully-Modular ATX Power Supply  ($54.99 @ Amazon)Total: $1408.50Prices include shipping, taxes, and discounts when availableGenerated by PCPartPicker 2015-01-06 14:07 EST-0500
Aside from the case this is the build I'd get.
https://linustechtips.com/topic/285746-budget-build-pc-help/#findComment-3879908
