Hi! I have the Corsair SPEC 02 case with this stuff inside:
- i5 4570 stock cooler
- G1 Gaming 970
I have 3 fans in total, 2 Corsair idon'tknowwhat and 1 Cooler Master Sickeflow. I have them configured like this:
- 2 front intake (Sickleflow and Corsair)
- 1 rear exhaust
But I see that the 2nd fan at the front doesn't do much because there's the drive cage, and I can't remove it.
So I don't know if it would be a little better to put it in the bottom, blowing air directly at the GPU. I have the front intakes filtered with some ghetto pantyhose, the bottom is filtered too but it's a crappy mesh that was included in the case, it kinda makes the job.
My PC isn't in the floor, is over a skateboard, because it's easier to move it when I want to clean it.
I also thought if it would be better to put the exhaust fan in the top instead of the rear, because heat rises...
What do you think guys?
Thanks in advance
https://linustechtips.com/topic/285669-where-to-put-fans/
Heat rising doesn't make any significant different inside of a case. Having the third fan as intake at the bottom would be best.
https://linustechtips.com/topic/285669-where-to-put-fans/#findComment-3878603
Why not filter the back fan and use that as intake, one front intake and then top exhaust (hopefully turbulence won't be too much of a problem), play around decide what works you.
Intel Core i5 4690K @ 4.2Ghz | Evga GTX 780 Ti SC ACX with backplate | MSI Gaming 9 AC | 8GB (2x4) Corsair Vengeance Pro Silver 2400 MHz | Corsair H105 128GB Crucial MX100 | Toshiba 2TB | Evga 750G2 | Corsair Obsidian 750d | Be Quiet Silent Wings 2 PWM (3x140mm & 3x120mm)
https://linustechtips.com/topic/285669-where-to-put-fans/#findComment-3878612
That doesn't mess with the airflow?
I mean, the air would be like this
https://linustechtips.com/topic/285669-where-to-put-fans/#findComment-3878630
Maybe, I would suggest you test a variety of configurations and decide what works best for you
https://linustechtips.com/topic/285669-where-to-put-fans/#findComment-3878637
So leave the exhaust at the rear, move one intake to the bottom? Sorry I didn't understood :P
Front intake, bottom intake, and rear exhaust.
https://linustechtips.com/topic/285669-where-to-put-fans/#findComment-3878872
