I need some help.  I'm going blind researching cases for my build.  It's coming down to the Phanteks Enthoo Luxe, NZXT Switch 810 or a Zalman (H1 or GS1000).  They all have some really great features and I probably don't need most of what comes with a case in this range but I really like these.  While I really like these cases, I'm not married to any of them.  I just want a long-term case that will keep my components cool and looks good.  Thanks for your help.
This is what I have to go inside:
Asus X99-Deluxe
Corsair H100 WC
SeaSonic SS-660 Platinum PSU
Asus Radeon R9 290X
1 - 2.5" SSD
2 - 3.5" HDD
https://linustechtips.com/topic/285193-atx-case-for-new-build/
Phanteks enthoo pro, H440 (silence, less airflow), define R4/5 (silence, less airflow), 450D
RIG: I7-4790k @ 4.5GHz | MSI Z97S SLI Plus | 12GB Geil Dragon RAM 1333MHz | Gigabyte G1 Gaming GTX 970 (1550MHz core/7800MHz memory) @ +18mV(Maxed out at 1650/7800 so far) | Corsair RM750 | Samsung 840 EVO 120GB, 1TB Seagate Barracuda | Fractal Design Arc Midi R2 (Closed) | Sound Blaster Z        Getting: Noctua NH-D15 | Possible 250GB Samsung 850 Evo        Need a console killer that actually shits on every console? Here you go (No MIR/Promo)
This is why you should not get an FX CPU for ANY scenario other than rendering on a budget http://linustechtips.com/main/topic/286142-fx-8350-r9-290-psu-requirements/?p=3892901 http://linustechtips.com/main/topic/266481-an-issue-with-people-bashing-the-fx-cpus/?p=3620861
https://linustechtips.com/topic/285193-atx-case-for-new-build/#findComment-3871922
I would recommend the Corsair 750D, I have it's smaller brotehr the 350D and I am loving it. It looks so clean and stealthy. If you are into some more bling the Corsair 760T is a great options with its all-acrilic transparent left side panel.
CPU: AMD Ryzen 9 - 3900x @ 4.4GHz with a Custom Loop | MBO: ASUS Crosshair VI Extreme | RAM: 4x4GB Apacer 2666MHz overclocked to 3933MHz with OCZ Reaper HPC Heatsinks | GPU: PowerColor Red Devil 6900XT | SSDs: Intel 660P 512GB SSD and Intel 660P 1TB SSD | HDD: 2x WD Black 6TB and Seagate Backup Plus 8TB External Drive | PSU: Corsair RM1000i | Case: Cooler Master C700P Black Edition | Build Log: here
https://linustechtips.com/topic/285193-atx-case-for-new-build/#findComment-3871945
