Hey everyone,
I just watched Linus's guide on overclocking for both Devil's Canyon and Haswell. I took some notes and got this basic diagram:
post-169860-0-57541500-1420484763_thumb.
I understand voltages and everything of that sort. I just have a few questions that weren't answered in the video:
1) What increments should you upgrade the voltages?
2) When the system crashes during a stability test, is any data lost?
3) Does cost reflect whether or not you won the silicon lottery?
My build is in my signature. Thank you in advance!
EDIT: How do you guys like Intel Extreme Tuning Utility? Should I use it?
4790k @ 4.6 (1.25 adaptive) // 2x GTX 970 stock clocks/voltage // Dominator Platnium 4x4 16G //Maximus Formula VII // WD Black1TB + 128GB 850 PRO // RM1000 // NZXT H440 // Razer Blackwidow Ultimate 2013 (MX Blue) // Corsair M95 + Steelseries QCK // Razer Adaro DJ // AOC I2757FH
https://linustechtips.com/topic/285076-basic-overclocking/
Use the spoiler for pics [******] [/******] @Slick @colonel_mortis is auto picture re-size down ??
  ﷲ   Muslim Member  ﷲ
KennyS and ScreaM are my role models in CSGO.
CPU: i3-4130 Motherboard: Gigabyte H81M-S2PH RAM: 8GB Kingston hyperx fury HDD: WD caviar black 1TB GPU: MSI 750TI twin frozr II Case: Aerocool Xpredator X3 PSU: Corsair RM650
https://linustechtips.com/topic/285076-basic-overclocking/#findComment-3870210
  1. I usually do the smallest possible increment, but it's personal preference really. Just don't over do it.
  2. Not unless you are working on something while you are stability testing
  3. Not with in the same CPU waffer. An expensive 4790K is not necessarily a better overclocker than a cheaper 4790K, and a 3930K is not necessarily a worse overclocker than 3960X. However, there are stores that sell cherry picked chips, and those will usually overclock a bit better.
Edit: I would actually recommend that you use Intel Extreme Tuning Utility. It's free and it works. Just don't use Prime95.
Nova doctrina terribilis sit perdere
Audio format guides: Vinyl records | Cassette tapes
https://linustechtips.com/topic/285076-basic-overclocking/#findComment-3870230
Sorry about that, I just put it under a spoiler!
https://linustechtips.com/topic/285076-basic-overclocking/#findComment-3870231
Thank you for your help!
Would you agree that Devil's Canyon max voltages are ~1.4?
https://linustechtips.com/topic/285076-basic-overclocking/#findComment-3870248
The max safe voltage is usually said to be 1.3v, but most don't recommend that you go above 1.25v.
While the H100i is a good cooler, the 4970K outputs a lot of heat when overclocked. So remember to watch your temperatures.
https://linustechtips.com/topic/285076-basic-overclocking/#findComment-3870285
Thanks!
https://linustechtips.com/topic/285076-basic-overclocking/#findComment-3870299
I ran a stress test and got 4.5 Ghz stable, but at 1.28V. I never touched the voltage. Should I turn it down?
https://linustechtips.com/topic/285076-basic-overclocking/#findComment-3870645
I guess that the voltage is still set to ´Auto´? I would suggest that you try to lowere the voltage, since the Auto setting is quite conservative when it comes to voltage.
I would also suggest that you run the stress test for a minimum of 12 hours, and 24 hours if you want to be sure it's stable.
https://linustechtips.com/topic/285076-basic-overclocking/#findComment-3870741
Alright, sounds good! My plan is to do 30 min stress test until I hit instability on 1.25V. Once I finish I'll confirm stability it with a 36 hour stress test. Does that sound good?
https://linustechtips.com/topic/285076-basic-overclocking/#findComment-3870867
That sound just fine.
https://linustechtips.com/topic/285076-basic-overclocking/#findComment-3870979
Thanks!
i'm running mine on 4.5ghz at 1.240 volts and its stable.
CPU: i7 4790K | Ram:Corsair Vengeance 8GB | GPU: Asus R9 270 | Cooling :Corsair H100i | Storage : Intel SSD, Seagate HDDs | PSU : Corsair VS 550 | Case: CM HAF Advanced.
https://linustechtips.com/topic/285076-basic-overclocking/#findComment-3871019
