http://uk.pcpartpicker.com/guide/tYgXsY/great-gaming-build
Hi there everyone I just wanted to get everyones opinion of this build. I wanted to know if theres anything I can change to get the best out of it! It will be used for gaming.. serious recording and video editing and internet use. I want to run most if not all game at very high to ultra settings and record at a comfortable frame rate.. 60 or more if possible.. Thanks
https://linustechtips.com/topic/285037-a-new-pc-build-help/
This looks pretty solid to me
Laptop - Lenovo Y50   Keyboard - Corsair K95 RGB Cherry MX Brown   Mouse - Logitech G502 Proteus Core   Mousepad - Razer Firefly
Please read the LTT Code of Conduct before submitting a post
https://linustechtips.com/topic/285037-a-new-pc-build-help/#findComment-3869779
Looks like a solid build!
PC Specs:
CPU: i7-9700k  | Motherboard: Gigabyte Z390 Aorus Elite | RAM: 16GB's Team T-Force Vulcan 3000MHz | GPU: Zotac GTX 1070 8GB AMP! Edition  | Storage: 500GB WD Caviar Blue | 1TB WD Caviar Black | Crucial BX200 240GB SSD | OS: Windows 10 64-bit  | PSU: EVGA SuperNOVA G2 650W 80+ Gold | CPU Cooler: Noctua NH-D14 | Mouse: Logitech G502 Proteus Spectrum Headphones: Sennheiser HD 598 Special Edition's, HD 598 Cs | Keyboard: CM Storm QuickFire XT MX Blues Monitors: Acer GN246HL 144Hz, Acer G226HQLBbd 60Hz | Case: Phanteks Enthoo Pro.
https://linustechtips.com/topic/285037-a-new-pc-build-help/#findComment-3869850
So should max all games? and recording well? How long would it work for or just depends on the usuage
Yes it will play all games on high settings and in a few years when games get more demanding you can add a second 970. you got the spare power in the PSU.
https://linustechtips.com/topic/285037-a-new-pc-build-help/#findComment-3869866
So the original one works best! I need windows 7 tho
The original is 10 pounds cheaper.  The real world difference is:  the original RAM would take 0.006875 (seconds) to respond to a request, the CL9 RAM takes 0.005625 seconds.  The CL9 is fancier though =D.
https://linustechtips.com/topic/285037-a-new-pc-build-help/#findComment-3871768
Could be much cheaper: http://uk.pcpartpicker.com/p/GR6Cqs
This belongs in the New Builds and Planning section. I'm moving the thread.
http://uk.pcpartpicker.com/p/X34xkL
How about this.. is the ram on this any better?
You need to quote a post or tag a member or else they won't get a notification you replied to them.
https://linustechtips.com/topic/285037-a-new-pc-build-help/#findComment-3871840
